May 11, 20213 yr I recommend using LDCad as well. Once you get the hang of it LDD feels like a Kid's toy, so much more possibilities. Edited May 11, 20213 yr by Gray Gear
May 11, 20213 yr Author Well, here are the final photos of my steering axle. Side part - replaces a part that is not inserted. 6 minutes ago, Gray Gear said: Я также рекомендую использовать LDCad. Как только вы освоитесь с ним, LDD станет детской игрушкой, гораздо больше неприятностей. But how to build in LDcad, I have not figured out yet.
May 11, 20213 yr 11 hours ago, Gray Gear said: I recommend using LDCad as well. Once you get the hang of it LDD feels like a Kid's toy, so much more pissibilities. I recommend editing that last word...
May 12, 20213 yr Author Here is the download link: https://bricksafe.com/pages/SUPER_Maks/-steering-gear-version-2
May 13, 20213 yr Author I would like to suggest something new: This is the rear axle that efferman did. I really liked it, and I want to do the same in LDD. The only but: This part is not in LDD. Edited May 13, 20213 yr by SUPER Max Black
May 13, 20213 yr Author This part was produced from 2003 to 2006. Edited May 13, 20213 yr by SUPER Max Black
May 13, 20213 yr Author Along the axis, here is more: More photos here: https://www.flickr.com/photos/57623735@N08/6808457665/in/photostream/ (To see everything, scroll to the right.) Edited May 16, 20213 yr by SUPER Max Black
May 13, 20213 yr 5 hours ago, SUPER Max Black said: The only but: This part is not in LDD. You can use brick-built solutions. Just make it a group and save as template. Then, each time you import the template it will be spawned as a group. Here's a functional version: download. It doesn't have the arch, but connections are accurate. Edited May 13, 20213 yr by syclone typos
May 16, 20213 yr Author At the moment I am sitting and doing the rear axle. I will show progress soon.
May 16, 20213 yr Please dont feel offended by this, but would you mind not bumping this topic unless you have something intresting to show? You don't need to post every single brick you put in place. Post something when you have made some moajor progress that is actually intresting for others to look at. For comparison: Other builders update their WIP topics maybe every few weeks at most, but often even less than once a month. And the updates are more than a single line of text with maybe one picture. Edited May 16, 20213 yr by Gray Gear
May 17, 20213 yr Author 22 hours ago, Gray Gear said: Nothing, I'll think about it. Speaking of the axis, here are the photos: What do you think about it? Now it remains to select the steering axle. Anyone have any ideas? Edited May 17, 20213 yr by SUPER Max Black
May 17, 20213 yr Author Here are other photos and LDD files: heavy-duty-truck-6x6 Edited May 17, 20213 yr by SUPER Max Black
May 17, 20213 yr Author On 5/17/2021 at 2:47 PM, SUPER Max Black said: Now it remains to select the steering axle. I need an dependent axis. There should be four studs from the wheel (center) mount to the frame. The axle should be thirteen pins wide. Anyone have any suggestions for this? Edited May 18, 20213 yr by SUPER Max Black
May 21, 20213 yr Author Well, here's what I got: This is just a sketch, but it fits perfectly with the servo motor.
January 11, 20223 yr Author I found the perfect example of a 4-speed transmission. Green - in Red - out I'm going to use it to build a truck.
January 13, 20223 yr Author Today I was digging through the files and found an interesting assembly. This is the rear axle. and center differential with rear axle lock: I think I will do the same in my future truck.
January 19, 20223 yr Author Today I assembled a simple 2-speed transfer case. As always: green - in, red - out. But I did not find a place for the blocker.
January 19, 20223 yr Author So I decided to download new parts for LDD. If it works, I'll show you. Edited January 21, 20223 yr by SUPER Max Black
January 19, 20223 yr Author I'm thinking of moving on to a separate topic on the truck. Edited January 21, 20223 yr by SUPER Max Black
