Posted May 14, 20213 yr Hello everybody, In this topic I'll put the different things I have in progress, (if any of them becomes consistent I'll open its own topic), and this way I won't put unfinished things in the general gbc thread. At the moment I'm experimenting with GBC, with the parts I have (mostly technic). As a sample, a test of Akiyuki's fork to fork mechanism, The truth is that I'm surprised that it manages to move balls. The conclusion for the moment : - recording with the mobile phone, turning the crank at the same time and catching the falling balls is difficult. -I need to register on youtube or instagram or something where I can post videos and not abuse gif files. I will continue with the trial and error to see what comes out. Regards
May 22, 20213 yr Author Hello, A little progress with this version of forks module: I have made the input with panels, a small wheel (not like akiyuki's which is much bigger) and surrounded it with wheel arch panels. I think it would work well as an independent module, just by changing the outlet that retains the balls to be caught by the fork. Next step - play with the inclination and height to join it later to the rest. Also, here's a picture of my version of the 9V control, so often used in GBC. I like that it has a panic button 😁 . By the way, what font size do you use in your posts? I have selected default on my smartphone, and when I post I see that it's bigger than the other users... Regards
