platinum831 Posted June 4, 2021 Posted June 4, 2021 (edited) hello i am working on a moc with multi link suspension it will have pneumatic cylinders as the shocks to act as air ride the steering of the suspension is a little funky and I don't know where i should mount the cylinders too in order to get full suspension travel with them installed any help is greatly appreciated Edited June 4, 2021 by platinum831 Quote
howitzer Posted June 4, 2021 Posted June 4, 2021 Copy the direct link to image file from Imgur (the one that probably ends with .jpg), then you will have the images in the post and not behind a link. Quote
platinum831 Posted June 4, 2021 Author Posted June 4, 2021 5 minutes ago, howitzer said: Copy the direct link to image file from Imgur (the one that probably ends with .jpg), then you will have the images in the post and not behind a link. thanks fixed Quote
amorti Posted June 4, 2021 Posted June 4, 2021 @nicjasnois your man for all things related to realistic suspension. Be ready though, he'll be quick to tell you if your design is pants. Quote
nicjasno Posted June 4, 2021 Posted June 4, 2021 (edited) Well, you want the truth, not lies. The main problem is the sway bar. Its position is not very good. You want it to be as narrow as possible, otherwise the axle will twist so much as to render its function meaningless. Also, as it is now, it's in the way of everything. Ideally you want your links to be vertical and slightly angled inwards. Edited June 4, 2021 by nicjasno Quote
platinum831 Posted June 4, 2021 Author Posted June 4, 2021 15 minutes ago, nicjasno said: Well, you want the truth, not lies. The main problem is the sway bar. Its position is not very good. You want it to be as narrow as possible, otherwise the axle will twist so much as to render its function meaningless. Also, as it is now, it's in the way of everything. Ideally you want your links to be vertical and slightly angled inwards. i have changed the position of the sway bar to a more inward approach but should i be connecting it to the knuckle instead of lower control arm as it just moves the arm and doesn't cycle the suspension Quote
platinum831 Posted June 4, 2021 Author Posted June 4, 2021 4 hours ago, platinum831 said: i have changed the position of the sway bar to a more inward approach but should i be connecting it to the knuckle instead of lower control arm as it just moves the arm and doesn't cycle the suspension moved to discord Quote
Lira_Bricks Posted June 5, 2021 Posted June 5, 2021 7 hours ago, platinum831 said: moved to discord Is it possible to share a summary or maybe even a screenshot of the conversation here when you are done? :) Quote
nicjasno Posted June 5, 2021 Posted June 5, 2021 A better version will be the result and will be shared here with an explanation. Quote
