Posted June 5, 20213 yr The set 8445 (Indy Storm) is a beautiful race car, it was the last studded set before lego technic goes studless. I start with the steering system It was the most difficult part to replicate due to its size. Edited June 6, 20213 yr by dickylaban
June 5, 20213 yr Nice choice for that model. You should upload your pics from bricksafe ou flickr for allow us to see something.
June 5, 20213 yr @dickylabanglad to see you are in this contest. Great set choice, and I am looking forward to the progress.Â
June 6, 20213 yr Author @Thirdwigg Thank you. The set is a small set & suit with my building style. @fosamax I have try to upload a photo, but only allow for small size. I'll try to link to my flickr account. Thank you. Â
June 6, 20213 yr eurobricks is not intended to store pics (that is in forum general rules, in fact). I recommend bricksafe.com
June 6, 20213 yr Author @Jurss Thank you for the info. Edited June 6, 20213 yr by dickylaban correction
June 6, 20213 yr Author @Scoar Sonander No, Same as the original steering system found in the set 8845. I recreate it with new Technic parts, it has the same turning angle. Â Edited June 7, 20213 yr by dickylaban
June 7, 20213 yr It is just hard to fit in that height and width something different in studless build. With studded it is easyer in fact. I'm also now struggling with 8440
June 7, 20213 yr Author @Jurss The steering system is the most challenging section to recreate with the new technic parts, my first picture is still the prototype & it already fully replicate the studded one.(3 stud height) I have do a little modification for the mounting of the surrounding parts.
June 7, 20213 yr Author I just try to mount the driving axle for the steering system. To mount this module, I'm planning to replace the axle with a longer one.
June 8, 20213 yr Author The front section already done, the steering system mounted at the same condition as the original set. The steering works perfectly as the original set. I didn't have yellow panels, so I decided to build my entry in white. Â The engine mounting is rebuild same as the original one but in studless. Edited June 8, 20213 yr by dickylaban
June 9, 20213 yr Author Studded frame in half (top) & the new studless version on bottom. Every position is replicated carefully, the gear box has to be modified due to the new mounting & gears. (but it still has the same position as the original)
June 10, 20213 yr Author The Indy Storm has already done in white, I'm not sure if this can be submitted.@Jim : can this qualified as an entry ? Â
June 10, 20213 yr Cool, I can see the similarity to the original... Can you open the hood? Do you use this part or some other mechanism? Â
June 10, 20213 yr 1 hour ago, dickylaban said: The Indy Storm has already done in white, I'm not sure if this can be submitted.@Jim : can this qualified as an entry ? What do you mean by "has already been done"? Each entry in the contest should be a new entry, not published before. But if someone else has done a similar MOC it's okay. Maybe not the best choice, also since the original is yellow. But that's up to you.
June 10, 20213 yr 1 hour ago, dickylaban said: No, I use this one :  Interesting choice... I wasn't even aware this part exists
June 10, 20213 yr Author @Jim I mean I just finished build this morning, I start building since 6 June. This is not an old build, please check my previous post.
June 10, 20213 yr 8 minutes ago, dickylaban said: @Jim I mean I just finished build this morning, I start building since 6 June. This is not an old build, please check my previous post. Then it's okay Â
June 11, 20213 yr Author 11 hours ago, BrickBuildingFox said: Interesting choice... I wasn't even aware this part exists This is the only one replacement for the pneumatic. Â
June 11, 20213 yr This doesn't happen often, but I think this build would really benefit from stickers! Easier said than done of course...
June 11, 20213 yr Author 3 hours ago, howitzer said: This doesn't happen often, but I think this build would really benefit from stickers! Easier said than done of course... Thank you for your suggestion, but unfortunately I'm not the sticker fan. I keep my build clean & I only do color combo when it is possible. Â
