shroomzofdoom Posted June 25, 2022 Posted June 25, 2022 1 hour ago, ord said: My instinct is to say no, as it could take resources away from developing the current IDE - which is so good and has features that I'm looking forward to. Agree 100% Quote
Lok24 Posted June 25, 2022 Posted June 25, 2022 There are already block based like https://bricklife.com/scratch-gui/ Quote
Polarlicht Posted June 25, 2022 Posted June 25, 2022 (edited) Alright my mans, got my Bluetooth thingy today and Cat and Volvo work. Had to use MS Edge, no BT on Firefox? Reinstalled Volvo software, and also the Cat works now with the controll! some questions: 1. The Volvo pulls ever so slightly to the left! Anyway to re-center the steering? Did a calibration in the Lego App just before the conversion... I tried steering speed on 900 and 1000, and steering hardness on 3 and 4... 2. What does the random white blinking mean on the control when you use it for some time? 3. How do i programm while the hub is connected? To change things "live"? 4. Where do i set how long it blinks blue after you turned the hub off? Edited June 25, 2022 by Polarlicht Quote
Lok24 Posted June 26, 2022 Posted June 26, 2022 21 hours ago, Polarlicht said: Had to use MS Edge, no BT on Firefox? No. 21 hours ago, Polarlicht said: What does the random white blinking mean on the control when you use it for some time? Low Battery? 21 hours ago, Polarlicht said: How do i programm while the hub is connected? To change things "live"? You have the programm in the editor window on code.pybricks.com, just edit and load and start with the ">" Botton 21 hours ago, Polarlicht said: Where do i set how long it blinks blue after you turned the hub off? If you turn the hub off it cannot blink anymore? Quote
Polarlicht Posted June 26, 2022 Posted June 26, 2022 (edited) ok thanks Edited June 26, 2022 by Polarlicht Quote
Pybricks Posted June 27, 2022 Author Posted June 27, 2022 Hey @Polarlicht, glad to hear you got it working! For your questions, I recommend playing around with just a hub and a motor, instead of everything built in. Then you can easily see what the lights do, what happens when you run motors, what happens when you turn it off, and so on. You can try many of the short example programs in the documentation on the right hand side to get some ideas. For specific questions about example projects like the volvo, please start a discussion here: https://github.com/pybricks/support/discussions That way the community member who made that program can help you. And others with the same question will be able to find it later. Quote
Lok24 Posted July 13, 2022 Posted July 13, 2022 Hi @Pybricks, just had the experience that motors with rotation sensor don't reach the same rotational speed when using "run" compared with "dc". "motor.run" results in app. 1000 (according to control.limits), "motor.dc" app. 1500. Changing "1000" into higher values (2000) shows no effect, neither in "run" command nor in "control.limits." How to improve? from pybricks.pupdevices import Motor from pybricks.parameters import Port from pybricks.tools import wait # Initialize two XL-motors on port A and B. m1 = Motor(Port.A) m2 = Motor(Port.B) #start both motors m1.run(1000) m2.dc(100) #wait and show results wait(1000) print(m1.speed(),m2.speed()) Results: 991 1555 960 1570 960 1570 991 1555 991 1555 Quote
Jonas Posted July 13, 2022 Posted July 13, 2022 Hello all, I have a question on using memory in EV3. I want to run a program in two modes. In the first one, I am going to do some calibration based on measurements from sensors and computation, and after that to store the computed values. This should be done only occasionally, especially in case when the working environment changes. In the main mode, the program should retrieve those stored values and use them for its repeated runs. What is the best way to do it in Pybricks? Quote
vascolp Posted July 13, 2022 Posted July 13, 2022 2 hours ago, Lok24 said: Changing "1000" into higher values (2000) shows no effect, neither in "run" command nor in "control.limits." That is strange. In my experience, doing: m1.control.limits(speed=2000) before calling run() should work. Try also changing the acceleration, if I remember the default is a bit slow m1.control.limits(speed=2000, acceleration=2000) Have fun! Quote
Lok24 Posted July 13, 2022 Posted July 13, 2022 Thanks a lot; I thougth this speed limit "1000" is a property of the motor, cause reading it when starting programm shows always the "1000" I can't test cause it is not possble to install new FW, "the Hub took too long to respond". So it's dead. Quote
Lok24 Posted July 14, 2022 Posted July 14, 2022 Yes, works as you described @vascolp my hub was disordered..... But what is the "correct" value for m1.run(xx) ? How to resolve it for the different motor types? Quote
vascolp Posted July 14, 2022 Posted July 14, 2022 7 hours ago, Lok24 said: But what is the "correct" value for m1.run(xx) ? How to resolve it for the different motor types? Good question! I think there is no generic solution for that. I do it like this (using excelent Philo stuff!): # Mode _bla_STP_SPEED assumes maximum speeds for each type of motor. # There are lots of motors, each one with its own characteristics, which makes it a bit difficult # to have a general purpose thing... # I got no-load speeds in https://www.philohome.com/motors/motorcomp.htm, multiplied by 0.9 # and got a list of maximum speeds per device. If the device does not match... it uses 1000deg/s (why not?). # # 1 Powered Up Medium Motor # 2 Powered Up Train Motor # 38 BOOST Interactive Motor # 46 Technic Control+ Large Motor # 47 Technic Control+ XL Motor # 48 SPIKE Prime Medium Motor # 49 SPIKE Prime Large Motor # 75 Technic Medium Angular Motor, gray # 76 Technic Large Angular motor, gray devs_max_speed = { 38:1377, 46:1700, 47:1780, 48:1230, 49:1150, 75:1230, 76:1150 } I got the above list of id numbers somewhere from pybricks github stuff, but I can´t find it right now ... You can get that id number from a port by doing: PUPDevice(Port.A).info()['id'] So, to get a device maxium speed on Port A I do: s=devs_max_speed.get(PUPDevice(Ports.A).info()['id'], 1000) Hope it helps! Quote
Lok24 Posted July 18, 2022 Posted July 18, 2022 Yes it helps. thanks The table is already there, because the programm supports all kinds of motors and changes method (run or dc) accordingly when starting. And the routine was already there, because I'm pretty sure that when first realesed the were values other than 1000, I think I rember 1400 for the Boost motor. I think it would be useful if Pybricks would offer the correct values when reading control.limits() Quote
2GodBDGlory Posted July 18, 2022 Posted July 18, 2022 (edited) I'm considering buying some more hardware to use with PyBricks in making more Mindstorms-esque stuff than I have to date, but I'd appreciate some clarification of its capabilities before I spend any money. 1. What options and limitations are there when using multiple hubs with PyBricks? I'd plan on using two Technic hubs, but I seem to recall hearing that PyBricks doesn't allow hub-to-hub communication. Is this true? What would the implications be for a model using two hubs? 2. Does PyBricks support all of the sensors available with the new style plug, whether Boost, Spike Prime, WeDo, or Mindstorms? I'd appreciate whatever clarification I can get! Edited July 18, 2022 by 2GodBDGlory Quote
Lok24 Posted July 18, 2022 Posted July 18, 2022 (edited) 19 minutes ago, 2GodBDGlory said: 1. What options and limitations are there when using multiple hubs with PyBricks? I'd plan on using two Technic hubs, but I seem to recall hearing that PyBricks doesn't allow hub-to-hub communication. Is this true? What would the implications be for a model using two hubs? This is planned. Implication is that the hubs are independent, but you can use one port at one hub as sender and one port on the other as receiver, so you can transfer information, but reduces ports to six. Or wait for the Pybricks hub-to-hub (perhabs its already available on beta) 19 minutes ago, 2GodBDGlory said: 2. Does PyBricks support all of the sensors available with the new style plug, whether Boost, Spike Prime, WeDo, or Mindstorms? You find them all on "code.pybricks.com" on the right side, look at "powered Up devices" ; if they are suppoeted with every hub? Suppose not. Edited July 18, 2022 by Lok24 Quote
David Lechner Posted July 18, 2022 Posted July 18, 2022 (edited) On 7/13/2022 at 12:18 PM, Jonas said: Hello all, I have a question on using memory in EV3. I want to run a program in two modes. In the first one, I am going to do some calibration based on measurements from sensors and computation, and after that to store the computed values. This should be done only occasionally, especially in case when the working environment changes. In the main mode, the program should retrieve those stored values and use them for its repeated runs. What is the best way to do it in Pybricks? You can save the calibration values to a file. In the calibration program, add something like this: import ujson calibration = {} calibration['value1'] = ... calibration['value2'] = ... calibration['value3'] = ... with open('calibration', 'w') as f: ujson.dump(calibration, f) In the main program, add something like this: import ujson with open('calibration', 'r') as f: calibration = ujson.load(f) value1 = calibration['value1'] value2 = calibration['value2'] value3 = calibration['value3'] Edited July 18, 2022 by David Lechner Quote
Mr Jos Posted July 18, 2022 Posted July 18, 2022 On 7/13/2022 at 7:18 PM, Jonas said: Hello all, I have a question on using memory in EV3. I want to run a program in two modes. In the first one, I am going to do some calibration based on measurements from sensors and computation, and after that to store the computed values. This should be done only occasionally, especially in case when the working environment changes. In the main mode, the program should retrieve those stored values and use them for its repeated runs. What is the best way to do it in Pybricks? #Removing the wms file for whatever reason you might need to delete it #os.remove("wms_hb_boxstatus.txt") #Create new file on first start ever create_file = open("wms_hb_boxstatus.txt", "a") create_file.write("") create_file.close() #Reading from offline file, store them in online list with open("wms_hb_boxstatus.txt") as retrieve_wms: wms_online_list = retrieve_wms.read().splitlines() #Adding extra positions at first start ever or expanding racks for x in range(total_storage_positions - len(wms_online_list)): wms_online_list.append("No box present") #Deleting extra positions when downsizing the racks for x in range(len(wms_online_list) - total_storage_positions): del wms_online_list[total_storage_positions:] #Store values from online list to the offline file def save_offline_wms(): with open("wms_hb_boxstatus.txt", "w") as backup_wms: for current_state in wms_online_list: backup_wms.write(current_state + "\n") def override_wms(): override_list = ["Gear 12T LBG", "Tile 3L LBG", "Tile 4L Black", "Liftarm 3L Yellow", "Pin 2L Black", "Gear 20T Blue", "Axle 2L Red", "Liftarm 11L Yellow", "MOTUS HANDLING", \ "Medium Actuator", "Small Chain Black", "Pin 3L Blue", "Gear Half 12T Tan", "Pin 3L Red", "Liftarm L 4x2 LBG", "Axle Hole Conn T1 LBG", "4Pin Conn LBG"] for x in range(len(wms_online_list)): if x < len(override_list): wms_online_list[x] = override_list[x] else: wms_online_list[x] = "No box present" os.remove("wms_hb_outsidestatus.txt") #Use hashtag # infront of next line of code if you DO NOT want to override! #override_wms() save_offline_wms() This is what I do in my warehouse to save the positions/names offline in a .txt file. Quote
2GodBDGlory Posted July 19, 2022 Posted July 19, 2022 12 hours ago, Lok24 said: This is planned. Implication is that the hubs are independent, but you can use one port at one hub as sender and one port on the other as receiver, so you can transfer information, but reduces ports to six. Or wait for the Pybricks hub-to-hub (perhabs its already available on beta) You find them all on "code.pybricks.com" on the right side, look at "powered Up devices" ; if they are suppoeted with every hub? Suppose not. Thanks! It's be nice to know for sure about sensor compatibility with that specific hub, but I guess there's not a lot of people trying to use sensors with that hub. Quote
Lok24 Posted July 19, 2022 Posted July 19, 2022 4 hours ago, 2GodBDGlory said: Thanks! It's be nice to know for sure about sensor compatibility with that specific hub, but I guess there's not a lot of people trying to use sensors with that hub. I think that it should work, @David Lechner @Pybricks should be able to answer that question; what I know is that there are some restrictions concerning the Move Hub. Quote
Pybricks Posted July 19, 2022 Author Posted July 19, 2022 Quote 2. Does PyBricks support all of the sensors available with the new style plug, whether Boost, Spike Prime, WeDo, or Mindstorms? Yes. And to be sure, you can click on "compatibility" next to each sensor. You'll see a list of all the hubs with a checkmark if it's compatible. For example, try it for the infrared sensor here. Which hub and which sensor would you like to use? Maybe we have an example program already. Quote just had the experience that motors with rotation sensor don't reach the same rotational speed when using "run" compared with "dc". We've recently made some corrections to this. The default values are defined here. For each motor, you can see the value for "settings->speed_max". Let me know if you think that some of these values are not right. To try the new firmware with these fixes before we release it officially, you can follow these instructions. Quote But what is the "correct" value for m1.run(xx) ? How to resolve it for the different motor types? Quote Good question! I think there is no generic solution for that. You can read the settings from the motor like this: from pybricks.pupdevices import Motor from pybricks.parameters import Port my_motor = Motor(Port.A) max_speed, acceleration, max_torque = my_motor.control.limits() print("max speed:", max_speed) print("acceleration:", acceleration) print("max torque:", max_torque) Quote
Jonas Posted July 19, 2022 Posted July 19, 2022 13 hours ago, David Lechner said: You can save the calibration values to a file. ..... Thank you David for this useful hint. Also thanks to Jos for his one. Quote
vascolp Posted July 19, 2022 Posted July 19, 2022 12 hours ago, Pybricks said: You can read the settings from the motor like this: Cool, thats an improvment! I just tested for the two motors I have at hand: I get: pybricks: 47 - Technic Control+ XL Motor:1525 76 - Technic Large Angular motor: 970 The values I used were 90% of philohome no-load characteristics, which are: 47 - Technic Control+ XL Motor: 1980 (330*6) 76 - Technic Large Angular motor: 1278 (213*6) What is the rationale of your values? Note, I am not telling that my rationale is better (on the contrary as I have no way of mesuring speeds). Just trying to learn. Thanks! Quote
Pybricks Posted July 20, 2022 Author Posted July 20, 2022 We use the values stored in the motor itself. We believe LEGO choose these so that most users can actually reach that speed. Without Philo’s special 9V supply :) But it is possible that the Powered Up app uses different defaults. To find out, just let the motor run at 50% speed and use a stopwatch to let it run for two minutes. Write down how much the motor moved in this time. Do it a few times for each motor type. Then we can calculate the speed. We’re happy to update our defaults to make them the same. Quote
vascolp Posted July 20, 2022 Posted July 20, 2022 Ok thank you. That seems indid the correct approach. I will start to use those values. Currently only on beta version, right? Quote
Lok24 Posted July 20, 2022 Posted July 20, 2022 21 minutes ago, vascolp said: Currently only on beta version, right? That's the problem, actual version code.pybricks.com (which is 3.1) always says max speed: 1000 acceleration: 2500 max torque: 260 for all XL, L and Boost motors And is was different a year ago, there I remember higher values. Quote
