Posted June 22, 20213 yr I have long wanted to make a replica 8880, but here is such a case... I doubt that will do very close to the original. But at least it is possible to withstand the scale (tires from Defender are great, the width and length will probably be 1 stud more). Edited June 22, 20213 yr by RazzPinazzo
June 22, 20213 yr Such a shame the more recent suspension parts don't have an Ackermann angle or a decent CV joint. Good luck, keep sharing :)
June 22, 20213 yr Author 48 minutes ago, amorti said: Such a shame the more recent suspension parts don't have an Ackermann angle or a decent CV joint. Good luck, keep sharing :) Thank you!) Ackermann - a question to be solved. But angles of rotation will be very sad. And unique gearbox shifter in original 8880 hrad enough to repeat
June 22, 20213 yr BOLD!!! This may very well be the most popular Technic supercar by OAFOLs out there. Good Luck.... I know I will be following closely....
June 22, 20213 yr By my reading, it is totally allowable to use the old shifter, that wouldn't take away from the overall studlessness.
June 22, 20213 yr I think the wheels from one of the newer supercars would be better to get the "modern studless" look than these. 7 minutes ago, ralphie said: By my reading, it is totally allowable to use the old shifter, that wouldn't take away from the overall studlessness. I wouldn't use the old shifter, that would be pretty boring. I think upgrading to something more than a 4speed would be a good idea. Edited June 22, 20213 yr by Gray Gear
June 22, 20213 yr 34 minutes ago, Gray Gear said: I think the wheels from one of the newer supercars would be better to get the "modern studless" look than these. I wouldn't use the old shifter, that would be pretty boring. I think upgrading to something more than a 4speed would be a good idea. Indeed. And if you insist on keeping the 4-speed gearbox, you could always simply have the changeover catch slide on axle for various positions, it's not hard to do. It might be harder to do it like the original, which had the stick pivoting with a ball-joint though...
June 22, 20213 yr Now we're talking :) I built all my childhood models mostly out of 8880 parts, as that was my only big set at the time.. Yeah, Defender tires are almost the same, only 2mm wider. A studless version of the manual 4-speed gearbox is pretty easy to replicate, I just did that in my Willys Jeep alternate of the Defender, exactly inspired by 8880. However, I agree that it could be a good idea to modernize it, but I would suggest instead of adding more speeds, adding maybe a DNR selector and changing the manual shifting to sequential shifting, but not as in the Defender, and not with paddles, but with the gearstick as in Nico's Ford F150. That would be more interesting for me, I have never seen that in other cars. 4 hours ago, RazzPinazzo said: Ackermann - a question to be solved That's also quite easy to do with the hubs used in the Defender by connecting a 2L liftarm to the hub. Good luck!
June 22, 20213 yr Author 4 hours ago, howitzer said: Действительно. И если вы настаиваете на сохранении 4-ступенчатой коробки передач, вы всегда можете просто установить переключающую защелку на оси для различных положений, это несложно сделать. Это может быть сложнее сделать, как оригинал, у которого ручка вращалась с помощью шарового шарнира ... I think I have an idea how to make a shifter with ball-joint. But no morr 4 speeds 29 minutes ago, gyenesvi said: Now we're talking :) I built all my childhood models mostly out of 8880 parts, as that was my only big set at the time.. Yeah, Defender tires are almost the same, only 2mm wider. A studless version of the manual 4-speed gearbox is pretty easy to replicate, I just did that in my Willys Jeep alternate of the Defender, exactly inspired by 8880. However, I agree that it could be a good idea to modernize it, but I would suggest instead of adding more speeds, adding maybe a DNR selector and changing the manual shifting to sequential shifting, but not as in the Defender, and not with paddles, but with the gearstick as in Nico's Ford F150. That would be more interesting for me, I have never seen that in other cars. That's also quite easy to do with the hubs used in the Defender by connecting a 2L liftarm to the hub. Good luck! Thanks! I want the gear lever to swing, not slide
June 23, 20213 yr Good luck on this build. You are certainly doing one of the most iconic sets, so I hope you can do it justice.
June 23, 20213 yr Author So I did not know, but technic ball can fit well between two liftarms and It will have 2 degrees of freedom (more precisely even 3) And everything would be great if not for the need for gaps (red lines on pic)
June 23, 20213 yr How about putting a lego rubber band on the bottom distance to act as a spacer/washer?
June 23, 20213 yr Author 13 minutes ago, SaperPL said: Как насчет того, чтобы положить резинку лего на нижнюю дистанцию, чтобы она действовала как прокладка / шайба? Brilliant! In the evening I will try
June 23, 20213 yr Go check out my crane instructions here: https://rebrickable.com/mocs/MOC-72143/SaperPL/mini-mobile-crane/#details (page 85 & 89/step 149 & 158) I used the small rubber band to make a spacer that's like 1/5~1/6 of a stud where I wanted to precisely position the differential between the floor and the steering shaft above it. But I did that on two axles spread apart, so if you do it on one, the loops may take a bit too much space. But the competition rules allow for non-lego rubber bands, so you may be okay even with something resembling an o-ring, I think.
June 23, 20213 yr 41 minutes ago, RazzPinazzo said: And everything would be great if not for the need for gaps (red lines on pic) This may still be too big, but in general, it's good to know that the One Ring can be used as a spacer that's slightly thinner than a half-bush. It was used as such recently in the Bird of Paradise set (10289).
June 23, 20213 yr This is going to be good! I'd actually forgotten what an absolute beast 8880 was, so glad for the reminder! I also agree that gear box approach that more speeds doesn't always equal more better - the size of the original gearbox is appropriate to the scale of the car (i.e doesn't make up a third of it!) and it has a mechanical legibility that defines this sets character and that is sorely missing from many later supercars.
June 23, 20213 yr A bold choice of model, indeed! You are confronting to a legendary model here, and very complex one, on top of that. Good luck, I will eagerly follow up your progress!
June 23, 20213 yr Author quietly moving on... I hope the black axles above gearbox will provide H gearshift scheme (more precisely, they will not be allowed to turn on two gears at once)
June 27, 20213 yr 50 minutes ago, RazzPinazzo said: <large image removed> Damn dude, this is starting to look great!
June 28, 20213 yr This is turning out really excellent. It's so evocative of the original even with most of the body still to build. I'm really looking forward to seeing it finished.
June 30, 20213 yr Author Current progress Chassis, transmission, suspension, steering (except HOG), engine and headlights is done Edited June 30, 20213 yr by RazzPinazzo
July 3, 20213 yr Author I can not understand. Everything seems to be clear in size, but body looks like piece of pancake... Who saw the real 8880? Horizontal windshield is normal? Upd: oh... I understood! A little bit better
July 3, 20213 yr I'm not so sure about this one, to be honest. For me it feels a little bit too much of a literal copy. It's not (yet) within the studless build style, it just uses studless parts. The bodywork especially, feels like a literal brick-for-beam replacement... I'd use more panels and flex-axles. I do like the white interior though :) That said, you certainly get all the points for recognizability ;) and you didn't pick an easy model. And it's good to see the 4 wheel steering working, so keep up the good work :)
