I have started building the 8846 Tow truck studless remake for the "[TC20] Technic Studless Recreation Contest"
BrickLink - Set 8846-1 : Lego Tow Truck [Technic:Expert Builder] -  BrickLink Reference Catalog
I have started with the front axle:
As you can see, I will use a bit wider tires, also It will be one stud wider, so it will be 13, not 12 studs wide.
Then, I have built the rear axle, and almost finished the chassis.
This is all progress for now, more in next post.
Edited by mic8per_
1 hour ago, Seasider said:
Only the first image is showing so far
Sorry for that, I have fixed that problem.
Edited by mic8per_
1 hour ago, caiman0637 said:
Ooh- good pick. I look forward to the final model!
Thanks!
The rear part is done:
Functions and mechanisms are the same like in the original model, just built with modern parts. I will improve the look of the crane and the look of the truck itself.
19 minutes ago, Jurss said:
All wheels woud be nice those narrow ones.
I know, but I don't have the corvette wheels.
27 minutes ago, msk6003 said:
Using LBG belt wheel for wheel cover and corvette tire for front knob(?) will good.
As I don't have the corvette wheels, I used a sprocket as a front knob.
Finished:
IMG_20210708_123635.jpgIMG_20210708_123715.jpgIMG_20210708_123829.jpgIMG_20210708_123856.jpgIMG_20210708_123957.jpg
All functions are the same like in the origilal model. The only one missing function is working steering wheel (out of space). Uses a bit wider tires than the original model. the front knob is a sprocket. both front and rear winches use 3rd-party strings, but LEGO-ones from the original set cal be also used.
There is still some time ;)
