Agent 00381 Posted July 23, 2021 Posted July 23, 2021 (edited) Ladies and gentlemen, sirs and miladies, I want to introduce you the Rolls Royce phantom V limousine 1960 James Young series!!!The process of creating this model took more than half a year, and I am very pleased to present you the result. In the model, I made sure that all the functions worked softly and pleasantly, and the body was strong and rigid for torsion and bending.Chassis Functions:1. Front independent suspension with caster and convergence2. Rear axle with Pahnar rod on springs made of pneumatic hoses, height adjustable3. Turning the wheels using the removable HOG or steering wheel in the cabin.4. Working "automatic" gearbox. There are D-N-R modes, they are switched by a lever from the passenger compartment, in D mode you can choose one of 4 speeds (movement of the red gear).5. The work of the fake V8 engineFunctions:1. Opening all 4 doors2. Opening of the 2-fold hood3. Opening of the trunk. There is a lock that supports the trunk in the open position and does not allow it to open spontaneously.4. Opening the glovebox5. Folding armrests in front and back6. Folding additional seats at the rear7. Rising partition between the driver and the rear passengers. Instruction Building process you can see in my inst: Edited July 26, 2021 by Agent 00381 Quote
Teo LEGO Technic Posted July 23, 2021 Posted July 23, 2021 Beautiful build! Nailed the colour scheme and the form of the car. Do you have any pics of the underside? Quote
1gor Posted July 23, 2021 Posted July 23, 2021 Sadly Lego does not have appropriate panels for such cars, only new plastic boxes are doable. That is the reason your work is even better Quote
Hrafn Posted July 23, 2021 Posted July 23, 2021 Can you explain what you meant by "panar traction"? "Panar" is not an English word as far as I can tell. Quote
Agent 00381 Posted July 23, 2021 Author Posted July 23, 2021 18 minutes ago, Hrafn said: Can you explain what you meant by "panar traction"? "Panar" is not an English word as far as I can tell. Its "Panhard rod", sorry, translation difficulties Quote
Agent 00381 Posted July 23, 2021 Author Posted July 23, 2021 (edited) 3 hours ago, Teo LEGO Technic said: Красивая сборка! Прибил цветовую гамму и форму автомобиля. У вас есть фото изнанки? I searched and was surprised, there are no such photos, but you can see the chassis details here https://www.instagram.com/tv/CM1SrtjJhF3/?utm_medium=copy_link Edited July 23, 2021 by Agent 00381 Quote
2GodBDGlory Posted July 23, 2021 Posted July 23, 2021 Very nice! I think that's the first time I"ve seen a gearbox of that style put into an actual model! Perhaps a white 20T bevel gear would make a more attractive steering knob, though they are rare. Quote
Thirdwigg Posted July 24, 2021 Posted July 24, 2021 Great design. I love the placement of the transmission, the fold down seats, and the two tone colors. The shape is perfect, and the opening hoods are great. Well done! Quote
MinusAndy Posted July 24, 2021 Posted July 24, 2021 Absolutely brilliant! Not just in terms of form but the functions are excellent too! Quote
T Lego Posted July 24, 2021 Posted July 24, 2021 Congrats on this replica! Great looks and functionality - well done! My only complaint would be the use of rigid hoses but I can see why you've chosen them. Too bad someone has stolen the spirit of extacy on your car Quote
Gray Gear Posted July 24, 2021 Posted July 24, 2021 (edited) I think the front looks pretty good, smooth lines! But the rear doesn't look that good imo. The bodywork looks a bit cluttered and doesn't flow very well. I like the removable HOG that removes the axle down as well. Not a big fan of the transmission tho. I tried it myself in the past, and it doesn't really run smooth and lacks a reliable mechanism to shift from inside the cabin. Overall a cool build. Edited July 24, 2021 by Gray Gear Quote
Agent 00381 Posted July 24, 2021 Author Posted July 24, 2021 (edited) On 7/24/2021 at 7:33 PM, T Lego said: Congrats on this replica! Great looks and functionality - well done! My only complaint would be the use of rigid hoses but I can see why you've chosen them. Too bad someone has stolen the spirit of extacy on your car Maybe spirit is hidden, as on the modern rolls I just couldn't find the suitable part Edited July 26, 2021 by Agent 00381 Quote
Agent 00381 Posted July 24, 2021 Author Posted July 24, 2021 2 hours ago, Gray Gear said: I think the front looks pretty good, smooth lines! But the rear doesn't look that good imo. The bodywork looks a bit cluttered and doesn't flow very well. I like the removable HOG that removes the axle down as well. Not a big fan of the transmission tho. I tried it myself in the past, and it doesn't really run smooth and lacks a reliable mechanism to shift from inside the cabin. Overall a cool build. Yes, maybe the the bodywork looks a bit cuttered for you, but there are not so many types of panels in lego and I tried to use them properly to make the model more plump and soapy in the right places. Can you tell me, which places you would like to change and what details you would put there. The same situation with the rear, what details of it you don't like? About the gearbox: there is not much space inside the hood, so I decided on this layout. The gearbox with a red gear works well if the shafts are spinning, and there is no more compact 4-speed gearbox in lego yet, so we have that we have Quote
Gray Gear Posted July 25, 2021 Posted July 25, 2021 (edited) @Agent 00381 the area above the rear wheels is the biggest weakspot. Maybe you could remove the small wing panels and use a 3rd flex piece instead to make it look more similar to the front wheelarch design? I know there would be some slight gaps, but I think it could look good. Edited July 25, 2021 by Gray Gear Quote
Agent 00381 Posted July 25, 2021 Author Posted July 25, 2021 12 hours ago, Gray Gear said: @Agent 00381 the area above the rear wheels is the biggest weakspot. Maybe you could remove the small wing panels and use a 3rd flex piece instead to make it look more similar to the front wheelarch design? I know there would be some slight gaps, but I think it could look good. Yes, I tried a lot of variations with the panels, that's the best. I would try using hoses if I had them and you would need to use more than one and this a bit destroys the concept: the upper and lower tubes seem to define the border of the wing Quote
PassengerJet Posted July 26, 2021 Posted July 26, 2021 I love this build! fantastic in every way Quote
sebulba56 Posted July 26, 2021 Posted July 26, 2021 A brilliant design here. I love how you recreated the very rounded shapes of the car. Quote
