efferman Posted August 1, 2021 Posted August 1, 2021 7 minutes ago, Attika said: but that printed rim isn't the same size as the lego counterpart, is it? 1mm more inside Quote
Bartybum Posted August 1, 2021 Posted August 1, 2021 Yeah I just tried it out, I don’t think there’s a way to have a one stud instep Quote
Teo LEGO Technic Posted August 9, 2021 Posted August 9, 2021 Out of curiosity, I'm also considering a rebuild of the chassis, what are some of the best steered live axles with diff locks that have been built in the past? The scale is the CLAAS tires, with a goal of bearing very high torque. Quote
alpinesman Posted March 1, 2022 Posted March 1, 2022 On 01/08/2021 at 13:36, efferman said: Une belle progression que je vois ici. Mon essieu a maintenant une instruction. (l'erreur de miroir est corrigée) https://bricksafe.com/files/efferman/vehicle-axles/42129 rearaxle fix.pdf Hi Efferman, I have seen the plans for modifying the axles. And I would like to do that. Does this require additional parts to the set? Thanks Quote
efferman Posted March 1, 2022 Posted March 1, 2022 10 hours ago, alpinesman said: Hi Efferman, I have seen the plans for modifying the axles. And I would like to do that. Does this require additional parts to the set? Thanks Yes it needs extra parts. Two 7*11 frames for example Quote
XilwEr Posted March 6, 2023 Posted March 6, 2023 On 3/1/2022 at 8:36 PM, efferman said: Hi Efferman thanks for plan of modifying the axles. I want to rebuild both front and rear, for rear i donwload the .io file than i can easy generate list of parts but for front axle i found only pdf. Can you share also .io file for ront axle? Or better share list of parts which i need to order to rebuild both axles on truck for my soon. Thanks a lot. Quote
flappybird906 Posted April 17, 2024 Posted April 17, 2024 I hope I can use this fix if cracking happens on my Mercedes-Benz Zetros Quote
XilwEr Posted April 17, 2024 Posted April 17, 2024 On 3/1/2022 at 8:36 PM, efferman said: Yes it needs extra parts. Two 7*11 frames for example dear @efferman can you please confirm than ony this two 7x11 frames are extra parts o I will need for the front more extra parts ? thanks a lot. Quote
