Cumulonimbus Posted June 16, 2022 Posted June 16, 2022 (edited) I once had the privilege to see a Sikorsky Sea king rotor head up close while a highly knowledgeable aerospace professor explain all the different mechanisms. It was an eye-opening experience, the complexity is just mind-boggling. Especially the different self correcting mechanisms, all purely mechanical are very impressive to see and learn about: One of the mechanisms which I will never forget is the spring loaded flapping hinge, which allows the blade to cope with sudden vertical gusts during flight. The amazing thing about this is the fact that there's another spring loaded subsystem, blocking this movement until the rotor speed is high enough in order to avoid hitting ground object while spooling up the rotor. When the rotor speed it high enough, the centrifugal force moves the locking mechanism in such a way that it frees up the flapping hinge to move. Add to this equation six rotor blades, a blade folding mechanism and very high safety factors ... simply stunning. The best image I found online of something similar to what I saw that day is this (from a Super Frelon helicopter): The said locking mechanism is the upside down T-shaped bar under each rotor blade. Edited June 16, 2022 by Cumulonimbus Quote
aeh5040 Posted June 25, 2022 Posted June 25, 2022 On 6/14/2022 at 6:38 PM, Blakbird said: From what I can tell from the helicopter photos, it will indeed have collective pitch (much like the original 852 helicopter in 1977), but what people are calling "cyclic" will really be a tilting head like 8856. I'd love to be proved wrong though. Really hoping you're wrong here too! I don't know but I think there is some reason for optimism. In the mechanism picture from the box, the "swash plate" seems to be tilted at quite a big angle, but the whole rotor does not seem to be tilted at a significant angle. Quote
abkdt41 Posted June 26, 2022 Posted June 26, 2022 42146 - any guess what color this set will be? I know its a long shot - but hoping for white Quote
Maaboo the Witch Posted June 26, 2022 Posted June 26, 2022 6 hours ago, abkdt41 said: 42146 - any guess what color this set will be? I know its a long shot - but hoping for white White with a yellow boom, I'm guessing. Quote
Bricktrain Posted June 26, 2022 Posted June 26, 2022 8 hours ago, abkdt41 said: 42146 - any guess what color this set will be? I know its a long shot - but hoping for white Factory colour is normally yellow superstructure and boom, white cab, grey undercarriage and counterweight Quote
Krika99 Posted June 27, 2022 Posted June 27, 2022 3 new photos were of the Airbus helicopter were posted on the Lego Technic facebook page. Quote
allanp Posted June 27, 2022 Posted June 27, 2022 I think this almost confirms the whole head doesn't tilt, and it's the individual blades that tilt as the head rotates. Looking forward to seeing how they did the cyclic/collective mechanism. Also looking forward to see what others do with the 5 way liftarm. Quote
nerdsforprez Posted June 27, 2022 Posted June 27, 2022 Perhaps the actual thread for this model should be updated with these photos. It will generate more discussion. Quote
Edwin Korstanje Posted June 27, 2022 Posted June 27, 2022 5 minutes ago, nerdsforprez said: Perhaps the actual thread for this model should be updated with these photos. It will generate more discussion. yep Quote
Jurss Posted June 28, 2022 Posted June 28, 2022 10 hours ago, allanp said: 5 way liftarm. What and where is that? Quote
KevinMD Posted June 28, 2022 Posted June 28, 2022 Can we take a moment to appreciate that kid’s hair? Are the side by side 1L liftarms (like mini-binoculars) on the rotor assembly new? I’ve never seen those before. Quote
howitzer Posted June 28, 2022 Posted June 28, 2022 1 hour ago, KevinMD said: Can we take a moment to appreciate that kid’s hair? Are the side by side 1L liftarms (like mini-binoculars) on the rotor assembly new? I’ve never seen those before. The part in question is this: Quote
allanp Posted June 28, 2022 Posted June 28, 2022 11 hours ago, Jurss said: What and where is that? it's the 5 sided piece that all the rotor assemblies are attached to, with the central beam running up through a square hole in the centre. Quote
Krika99 Posted June 28, 2022 Posted June 28, 2022 (edited) I actually totally forgot about about the dedicated thread, where are are some better pics of the swashplate mechanism: From what it seems, we'll get full collective and cyclic controls! Edited June 28, 2022 by Krika99 Commentary on the helicopter mechanism Quote
Gimmick Posted June 29, 2022 Posted June 29, 2022 On those images it looks like this model almost perfectly balances out the unsolveable equation of visible-but-hidden-technic-inside + functions + educational behavior + playability + looks + motorization + kind-of-old-fashion/nostalgic-but-new. So i guess there will be a lot discussion about the license and the gear colors :X Quote
aeh5040 Posted June 29, 2022 Posted June 29, 2022 I'm surprised by how insecure the attachment of the new 5-way liftarm appears to be (given the weight of the rotor). If I'm interpreting it right, the square hole in the centre slides onto the vertical liftarm, and the only thing holding it in place vertically and stopping it from wobbling is the offset connector just below it and the offset axle running vertically through one of the holes. Judging by the other arms, it is a pin hole not an axle hole, but who knows? Perhaps the square hole is a very tight fit, which would help with wobble? I agree, the evidence in favour of genuine cyclic now looks very strong! Quote
Jim Posted June 29, 2022 Posted June 29, 2022 Let's try to keep the conversation in the dedicated topic. Makes it easier to follow the discussion. Quote
Maaboo the Witch Posted July 3, 2022 Posted July 3, 2022 Apparently there's a "Monster Jam Collection" set. I'm guessing it includes all trucks released thus far and I'm really hoping it doesn't mean that TLG is done with the Monster Jam subtheme. Quote
msk6003 Posted July 4, 2022 Posted July 4, 2022 11 hours ago, Maaboo35 said: Apparently there's a "Monster Jam Collection" set. I'm guessing it includes all trucks released thus far and I'm really hoping it doesn't mean that TLG is done with the Monster Jam subtheme. I want see bone shaker in next line but also I want end of monster jam line. I want see old on-road pull back cars like dragster, F1, hot road. Quote
Akbalder Posted July 4, 2022 Posted July 4, 2022 14 hours ago, Maaboo35 said: Apparently there's a "Monster Jam Collection" set. I'm guessing it includes all trucks released thus far and I'm really hoping it doesn't mean that TLG is done with the Monster Jam subtheme. A Lego page shows the 4 existing monster trucks: https://www.lego.com/fr-lu/service/buildinginstructions/66712 Quote
Timorzelorzworz Posted July 20, 2022 Posted July 20, 2022 Does anybody know what happened to the number 42142 this year? It is still missing. Quote
Maaboo the Witch Posted July 20, 2022 Posted July 20, 2022 58 minutes ago, Timorzelorzworz said: Does anybody know what happened to the number 42142 this year? It is still missing. I know, I saw it on the milk carton this morning. Quote
Jockos Posted July 20, 2022 Posted July 20, 2022 Actually, I'm hoping for a surprise/not announced set for October (as was the case for Land Rover?). So who knows.. TLG is doing a bit better at set leaks Quote
Jundis Posted July 21, 2022 Posted July 21, 2022 25 minutes ago, mortenm said: Liebherr crawler crane? The Liebherr is listed as 42146... so maybe a surprise for October or another skipped number (like 42085...87). Quote
