gyenesvi Posted October 17, 2021 Author Posted October 17, 2021 On 10/15/2021 at 8:59 PM, Zerobricks said: Also what matters is where you attach the steering arm to the hub. If you attach it at the same level as the upper arm, than the slight tilt of the hub will have a zero affect. If you attach all the way on the height of the lower arm, than it will matter a lot. In the original build, it is actually attached on the same level as the upper arm, I guess that's why I observed less toe out in that case, than with the modified build. However, I think what you say is only true for non-Ackermann geometry, for Ackermann, still there's a very slight offset. Furthermore, the effect is only totally zero if the steering link is attached with a towball pin, so that the link can rotate on the pin and is not effected by the tilt of the hub. Quote
Didumos69 Posted October 19, 2021 Posted October 19, 2021 (edited) Interesting read, nice to get an impression of the process. Very recognizable too. An alternate model always comes with compromises. And the end result is something to be proud of. Suspension setup is great as is the bodywork. I'm working on an alternate build of the Zetros myself and I can confirm it's very hard to put together a sophisticated suspension setup with the available parts. Edited October 19, 2021 by Didumos69 Quote
gyenesvi Posted October 21, 2021 Author Posted October 21, 2021 On 10/19/2021 at 7:42 AM, Didumos69 said: I'm working on an alternate build of the Zetros myself and I can confirm it's very hard to put together a sophisticated suspension setup with the available parts. Thanks, looking forward to what you come up with out of this set! Quote
Volt01 Posted February 26, 2023 Posted February 26, 2023 your build is the whole reason i bought the set in the first place, im in love with the classic unimog and your version is AMAZING here is my build https://drive.google.com/drive/folders/1rH194NHBHiZQoMxbgk1Bm9hwhB4o4VjA?usp=share_link Quote
gyenesvi Posted February 27, 2023 Author Posted February 27, 2023 20 hours ago, Volt01 said: your build is the whole reason i bought the set in the first place, im in love with the classic unimog and your version is AMAZING Thanks a lot, glad you like this one! :) Quote
