This MOD upgrades your CAT D11 as below:
- increase the blade lifting speed by 67% (the Control+ app needs to be calibrated after this MOD)
- close the gaps near the front panels
- make the front linear actuators look stronger
- replace the rear fake linear actuators with a real one; they can be controlled manually to tilt the ripper
- add 2 fire extinguishers near the cabin
115 extra parts are needed. The most expensive parts are the 2 black linear actuators (43097). Replace them with the LBG one (61927b) is fine. Or just like me, sprayed the LBG one with semi-gloss black.
Instruction available at https://rebrickable.com/mocs/MOC-91485
Enjoy and have fun!
Edited by A_C
10 hours ago, Richombx said:
Using the compare parts feature I see that you have the 115 parts split into two groups, is there a reason for this?
You don't have to use that compare parts function. The 115 parts are already the extra parts needed for this MOD.
It's just updated to v1.1:
- hide the blade's tilting shafts on both sides (the Control+ app needs to be calibrated after this MOD)
- change the headlights position
- add side mirrors
- need 84 more parts than v1.0; a CSV file is provided for download
Edited by A_C
I think the best way is to use the ladder manuell and the Rc function for the 2 new Ripper actuators or manuell switch between Rc ladder and Rc Ripper actuators
Edited by Al Ex
That's a nice thought, but definitely out of my skill.
The best way is to go full PF :laugh:
