2 hours ago, sondh said:
May I ask if this would work with Power Function motors and battery box?
Yes, I did a PF mod for this set.
Thanks anh Ngọc, I did tinkering around with your zetros PF mod. Now I am eager to try a new build with the zetros parts, with the PF system.
I can share the PF mod if you contact me.
Thank you kindly, anh. Unfortunately I can't DM you here due to my account limitation. Is there any other way to reach you?
I thought it should be doable, and glad to hear you did it, thanks! I guess only the servo replacement is not trivial because of the different shape, the rest (L motors, M motors, maybe even battery) should be relatively simple.
Maybe you can share it in your PF mods thread? Or you want to keep that for official models only?
3 hours ago, steph77 said:
This one deserve to be frontpaged, i think!
Thanks for the support, but I guess it's been a while since this was published.. (almost exactly 3 years now!)
I thought you dont want me to share it publicly.
I used the M motor for steer.
Oh, that's right, not the whole model. Not sure if it's possible to share just some ideas / renders about the modification for the steering itself. Maybe you could post some renders about that part here in this thread then for guidance for those who'd like to modify it, this may be a better place for that, and that way your thread is not polluted. Up to you, I'm okay with that.
I see, can also work. Did you do down-gearing? Doesn't that take up more space?
Behold, the power of squeezing!
Thanks, that's a good summary of all the replacements! As for the steering, I guess in the same amount of space, a servo could also be fitted.
