Posted January 8, 20223 yr I'm using Studio version 2.2.11 and I am trying to mate tire 3139 to hub 3464 without any success. Has anyone else had this issue?
January 8, 20223 yr I can confirm those parts do not connect together, but they are supposed to be compatible. If you manually place each piece at coordinates (0,0,0), they will line up with no collision. I'd just line them up, merge them into a sub-model, and use that.
January 9, 20223 yr Author On 1/8/2022 at 9:35 AM, NathanR said: I can confirm those parts do not connect together, but they are supposed to be compatible. If you manually place each piece at coordinates (0,0,0), they will line up with no collision. I'd just line them up, merge them into a sub-model, and use that. Thanks for the reply. I was ultimately able to solve it by putting the parts together in LDD then importing into Studio. At least now I know there is another way.
