I'm trying now to build two other modifications of John Deere 9620R, they were my very first idea when I ever found the number of sub-models of this machine:
  • John Deere 9620T with a pair of rubber tracks and without rear articulated part.
  • John Deere 9620RX (a lazy modification) with triangle tracks instead of wheels.
17 hours ago, 1gor said:
And topic says: 24136...
Oops! Fixed, thanks!
19 hours ago, Jurss said:
Where is Your mod, as You started topic?
Who says i have to add my mod to the first post? I just did this topic to see what mods people come up with!
I don't have the model yet! There are no such rules!
The title of your thread creates certain expectations. At least I and probably other people too were expecting to see your mods or any other substantial contribution/content. I was a bit disappointed to see nothing.
You could have made it obvious in the title or at least in you first post, that you are looking for mods and don't have any by yourself because you don't have the set yet.
9 hours ago, M_longer said:
Half alternate model, the SIlage Blade, with instructions :)
Very easy but cool alternative :-)
But the blade too wide for my taste, you could easily take out the most outward mounted panels and even the 1x7 liftarms and still have a decent size :D
But then it will be not 100% parts usage ;)
Simply use the left-over parts for a hayroll. ;)
Edited by R0Sch
There might be a way to actually put in a 4WD without widening the chassis and still keep steering function as it was. The trick is to use 2 pairs of bevel gears to go around the rear differential down to the turning table.
But there is no chance for a fake engine under the hood with a mounted front differential. Rear wheel diff only with fake engine might work though.42136_mod_1.jpg
Lego Technic 42136 4x4 mod and engine..
This mod maintains the original build to the best I can design with the original wheelbase and height. It’s only 1 brick longer due to rear differential design.
Features:
AWD 4x4 drivetrain
Mini 4 cylinder engine
Detail engine with radiator
https://youtube.com/shorts/f5LFYIMXChs?feature=share
Edited by sirslayer
Nice work! But what does the small turntable do? The black part doesnt seem connected to anything?
The turntable for now is to provide the turning pivot and in a future revised I need to raise the rear top lid section by one brick to fit the steering mechanism.. I just wanted to show a working prototype !!  But I just received the Technic 42139 yesterday and I’m building in a awesome model B
You’re right!! I’ll fix that my friend!!
Lego Technic 42136 4x4 engine tire modLego Technic 42136 4x4 engine tire mod
Oh man!! I forgot to turn the rear tire !!  At least that you can steer and the tires won’t touch!!
Hey fellows...
I made some attachments for the John Deere 42136.
KUHN Grand Prime seed drill
Amazone UX 11200 trailed sprayer
1000x800.jpg?1647202769.2117326
Zunhammer SK ECO tridem Slurry Tanker
1000x800.jpg?1647268171.175584
You can find details, instructions and videos when you click on the pictures (if I made this correct).
Let me know your opinion about them.
