May 20, 20222 yr Good luck @jorgeopesi, I’m looking forward to the end result, hopefully you will be able to finish this soon promising dumper.
May 20, 20222 yr Author 6 hours ago, Thirdwigg said: I hope you are able to finish. It looks close.... Me too but our concept of close MOC is not the same at all... unfortunately for me . 40 minutes ago, GerritvdG said: Good luck @jorgeopesi, I’m looking forward to the end result, hopefully you will be able to finish this soon promising dumper. Thank you, I think the same, I want to finish it whatever before of after the final date, the important thing is I build again.
May 20, 20222 yr Nice to have you active again. Great work thus far! Quite excited to see the end result, no matter if you finish it in time or not. This is shaping up to be a great model! _ED_
May 22, 20222 yr Author On 5/20/2022 at 11:52 PM, Nazgarot said: Nice to have you active again. Great work thus far! Quite excited to see the end result, no matter if you finish it in time or not. This is shaping up to be a great model! _ED_ Thank you for the kind words. I totally redid it again but I was lucky everything was better than I expected, that is why my MOCs take a too much time... I did not like enough the suspension in the middle, it was realistic and very stable but it had a little weakness due the small turntable and I also had lost space for the bed... so we have again a bigger bed, pivot suspension in the front axle a new and more playable steering with better general looks IMO, the MOC is now more simple but I think is better. Edited May 22, 20222 yr by jorgeopesi
May 22, 20222 yr Looks better now Could you use the 5x11 tapered panel for the side of the bed? Looks imho better than the stacked liftarms :-)
May 22, 20222 yr Author 3 minutes ago, Jundis said: Looks better now Could you use the 5x11 tapered panel for the side of the bed? Looks imho better than the stacked liftarms :-) I tried to do it but I did not find an enough strong way for my taste to put them, I also tried with the 3x5x3 curved panel with same result... it is important for me to have that angled bed because the real ones are that way for gain more maneuverability inside tunels.
May 22, 20222 yr 1 hour ago, jorgeopesi said: I tried to do it but I did not find an enough strong way for my taste to put them, I also tried with the 3x5x3 curved panel with same result... it is important for me to have that angled bed because the real ones are that way for gain more maneuverability inside tunels. Did you try with this?
May 22, 20222 yr Author 3 hours ago, 1gor said: Did you try with this? I have a couple of them in the bed but I will give a try just to see...
May 22, 20222 yr 5 minutes ago, jorgeopesi said: I have a couple of them in the bed but I will give a try just to see... It solved lots of my problems I keep my fingers crossed.
May 26, 20222 yr Author 16 minutes ago, 1gor said: Front part looks great Thank you, it was difficult to use the liftarm with angles but it was important for my idea of a realistic MOC unfortunatelly I had to remove the working steering wheel because time runs fast.
May 28, 20222 yr Author MOC finished. It was a lot of fun to do it. Features: Front pendular suspension Pneumatic bed 4x4 with 2 differentials Inline 6 cylinder engine Openable hoods and cabin door Retractable small ladder Hand of god steering Modular design https://www.youtube.com/watch?v=XVgTGcw9NVo Edited May 28, 20222 yr by jorgeopesi
May 30, 20222 yr It turned out great, and I'm happy you were able to finish the MOC. The management of all the hoses is perfect.
