Hey, this is my another Chevrolet model in Creator Expert scale - Impala '64.
img%5D
Length: 39,2cm /49 studs
Width: 15,2cm /19 studs (18 without grey bars)
Functions:
- working V8 engine (powered by a differential)
-working steering wheel
-openable doors, hood and trunk
Please watch the video :) I'd be grateful for feedback!
Photo gallery: https://flic.kr/s/aHBqjzJRiP
Rebrickable: https://rebrickable.com/mocs/MOC-107777/syzygy87/chevrolet-impala-ss-1964-creator-expert-scale/#details
Instagram: https://www.instagram.com/kuba_lego_moc/
Youtube:
Edited by Milan
Moved one picture for frontpaging.
Looks very true to the original! I mean, the real car looks like it was designed with making a LEGO build in mind, no curves or other problems. But still, very well done.
Only thing I dislike is that there is a transparent piece in the rear window, but nowhere else. That looks weird.
Not a best moment to publish such a beauty (because of all those contest entries). But maybe it will find a way to frontpage.
  • Milan featured this topic
Oh, there are some curves on the sides of the car, that's why they are built with SNOT technique :) But in general you are right, the older cars are easier to replicate with lego :)
Yes, you are right, there is some inconsistency. But LEGO doesn't use side windows (most of the time) either, so only the front one is missing. I couldn't fit anything in there - the windshield from the ECTO didn't fit, even though it was the closest.
23 hours ago, Mechbuilds said:
Looks great but that engine and enginebay needs work.
Yes, you're right - I already had limited space there, the long black plates support the sides of the car which had to be reinforced somewhere, increasing the lack of space.
I know, the V8 should be a bit more in the back, however there I have a steering layout and I couldn't fit it. The alternative is a creator expert style engine, however I preferred it to move :)
22 hours ago, Milan said:
And it just did find a way :)
Frontpaged.
Wow, I didn't expect that at all! Thanks a lot!
Thank you all for your kind words!
I used to drive a 1964 Chevy Malibu, a very similar in appearance model, with the Impala SS of course having the more powerful engine (ours was a straight 6 - or, was it a 4 cylinder???). Those '64's were nearly indestructible, I sold mine in 1983, and saw it running around town for at least 5 years after. Aside from the fact that mine was blue, this LEGO model is nearly dead-on accurate (except for the shag-rug covering the rear deck that everyone added to cover the peeling surface). The only significant detail that is missing are the triangular opening "air-conditioner" window insets in the L/R door windows. Great job!
Edited by JGW3000
If you've played Carmageddon before - Otis Jivefunk drives this:
It's a caddy, but not that far off from your car. Add some spikes and fins and it's a Carmageddon car :D
Now - seriously, I'm stunned by your build. Great work.
