Greetings,
I am currently in the need of some sort of software that can control Powered Up Hubs using a form of programming language other than block coding. I've been having difficulty getting repositories such as node-poweredup and Brick Automation Project to work. The application for BAP works, but I want to be able to actively control the hub like you can with the Powered Up app.
If you have any guidance on how to get the aforementioned repositories working, I would greatly appreciate it. Or if you know of another piece of software I haven't tried yet I would greatly appreciate that too. I would prefer the software have a language similar to Java, or anything similar like C#, but at this point I couldn't care less. I just really want to code these things.
Thanks.
sharpbrick/poweredup seems to work in Powershell, but I can't get it to work in Visual Studio. Since this has been the pattern with everything I've tried I'm assuming it's something to do with me. It says it can't find a project when running and it has a lot of problems. I imagine there must be something more to do than just cloning the repository.
I don't know these repositories but Pybricks is a free and well rounded package to control the PoweredUp hubs and devices with easy coding in Python. Comes with its own repositories, works from the browser and can flash to the hub with firmware to work without device.
Does Pybricks allow you to control your motors? Not just make code and have the motors follow it in sequence? I want to control it like I would from the Powered Up app with some form of user input.
really want to use some sort of repository for controlling motors, that way I can use a controller that's not the PU remote. The PU remote limits my controlling options quite a bit. I also don't feel like learning python and buying a PU remote to use. I guess I just need someone to enlighten me on how to get these repositories working.
Not sure how you came to that conclusion. The PU remote is actually quite a good solution. I never thought I'd say this but having recently gotten into C+/PU, I think it gives one far more "controlling options" than any other LEGO motorisation system as it allows one to  fully program everything, motors, leds buttons remotes and sensors to do exactly what one wants. I motorised the drive, steering and gearbox of my 42110 set with C+ and the PU remote in less than 250 lines of code, and that's with multiple control modes.
My main issue with C+ though is that the L and XL motors are utter junk and the requirement to flash third party bootloaders to make C+ actually usable.
Well, I mean, if you can't be bothered to put the effort in to learn one of the easist programming languages around and spend £5 on a remote........
Hmmm ...
Let me wrap this up:
  • You don't want to learn Python or better Pybricks, which is a lot easier, as it is tailored towards PUp.
  • The PUp remote is not an option, because ... it has only 7 keys to use, correct?
  • A smartphone is not an option, because ... why exactly?
Would you be comfortable making your own key type interfaces?
I don't understand what you really want, with what kind of effort.
Best,
Thorsten
Maybe I'm just underestimating what the PU remote can do, but I don't think the amount of buttons will do it for me. I see myself controlling like 4 individual motors, which I don't think can be done with a PU remote. With a PU remote I feel like I'd only have the amount of buttons to move, and enough buttons left over to fully control one more motor. I guess I can get the amount of buttons I need by using Pybricks and keyboard control. Ideally I would like to use something like a Xbox controller to control everything. That's mainly why I want to use a repository so I could stick in some other code to let me use a controller like that.
Coding language doesn't necessarily matter. It's mainly the amount of control I have. I'm not too lazy to learn Python, I'm just a bit too picky. I would prefer something like C+ just for ease of use. But I suppose I should be more open if I plan on accomplishing anything.
You can use 2 PU remotes, it's LEGO so you even have connection points to attach them to each other ;)
If you want to simply control those motors with an Xbox controller then there's Brickcontroller 2. Otherwise I really suggest Pybricks, that might be the most versatile solution.
Btw Mindstorms / Spike Prime now also have the ability to use Xbox/PS4 controllers. It will only work with the 6 port hub, but it works.
None of these might the the exact solution you wanted to see, but I think there are enough options to choose from :)
Yes the PU remote has 7 buttons (i.e, control of 3 motors) but one should be able to use the centre green button as a shift button to allow you to add a second set of 3 motors like I did with the mode select on my Land Rover.
Sure, I already showed a complete railway layout, level 1 for engines 1+2 , level 2 for all switches, signals, railroad crossing.
There I used BAP, but for other projects I usesd an ESP with legoino, which should allow other input media too, especially build from other PU-Components, or Gamepad or more than one remote  .......
Edited by Lok24
  • 2 years later...
On 5/24/2022 at 1:20 PM, Blocker_Buddy said:
Greetings,
Thanks.
@Blocker_Buddy,
If you have the 51515 Robot Inventor Hub or Spike Prime Hub, you can connect the motors  to that and use it to program the motors. (Scratch or Python)
Is also use up to 4 modes with the PU remote and Pybricks with the center green button as a mode switch button. That's 6 x 4 = 24 options to control. You can also use pre-programmed motions like I also did in my Load Zone project. One button press moves the fork-lifter to fetch or put a pallet using 3 motors. Recently support for Xbox controller has been added by Pybricks. So may be it's time to learn a bit of Python. Worst thing that can happen is that you learn something.
If by chance you're still looking for solutions two years later, good news - Pybricks now supports Xbox controllers!
