bogieman Posted June 10, 2022 Posted June 10, 2022 As a bogie designer, I have always been intrigued with the 8-axle first and second generation Gas Turbine Electric locomotives (GTEL) built by GE in the 1950's for the Union Pacific RR. These used a single gas turbine rated at 4,500 HP and rode on a pair of span bolster 4-axle bogies comprised of a pair of 2-axle equalizer bogies with the draft gear and coupler carried integrally on the span bolster casting. I'm sure the designers did this to limit the length of coupler required to negotiate a reasonable minimum curve radius - this arrangement is similar to most all Lego trains where the bogie carries the coupler. These were long locomotives, 83.5 feet over couplers (25.5m). Besides the gas turbine, they had a small diesel engine for hosteling and to start the turbine engine. Unfortunately, all of the first and second generation locos were scrapped, the bogies saved and later used under GE U50 locomotives. The third and last generation had a larger 8,500 HP turbine and was two six axle locos coupled together - two of those were saved and are in RR museums. Here's a photo of the first generation loco I modeled: I I modeled it in 1:48 scale (8 wide); Andy at OKBrickworks created the decals for it: I 3D-printed the windshield frame as I did for my F7A model and painted it a reasonably close match to Lego Yellow. The model is powered with 4 PUP train motors that I modified by replacing the PUP cable with a pair of very flexible wires that pass into the carbody to connect to the controller, a SoundTrax Tsunami 2 4400 DCC which has a 4 amp capacity. It's powered by 4 - 18650 batteries in series giving nominally 14.8V to an Airwire Convrtr 60X that receives commands from an Airwire wireless throttle which it translates to DCC commands to drive the Tsunami 2. Sound effects from the Tsunami 2, which include all the turbine sounds, a played thru a 40mm in the "battery box" between the bogies. It also controls the lighting effects. This system is step up from the MRC LocoGenie I've used in my previous Lego locos for motor control, sound and lighting. With the long, wide carbody, there is plenty of room for the batteries and electronics. The roof lifts off in two parts to access the batteries and power switch. The Airwire receiver is visible in the picture, the Tsunami board is below the red tiles beneath it. The Airwire and Tsunami can both take up to 24V input, so I went ahead with 4 battery cells instead of the 3 I usually use. I've done a lot of pulling with this loco up the 4% grade on my layout with heavy trains and the train motors seem fine so far. Here is very long video showing the model in action before the decals were applied: The final tasks I have yet to do is to rearrange the cab interior to fit a pair of minifigures and create a fuel tender. Dave Quote
DMRR WOLFE Posted June 11, 2022 Posted June 11, 2022 Ok! That is sooooo coool!!!!!!! I've never seen anything like that before! I can't imagine how you got that bogie configuration to work!!!!! You are really talented!!!! Quote
bogieman Posted June 11, 2022 Author Posted June 11, 2022 Thanks! I didn't mention it, but the bogie bolsters have a pitch degree of freedom relative to the underframe so they can negotiate vertical curvature in the rail profile, which they need to make it up and down the grades on my layout where the transitions are not as gentle as they are on real railroads. I designed locomotive and freight car bogies for 40 years so I do have some experience in the field. Dave Quote
zephyr1934 Posted June 11, 2022 Posted June 11, 2022 Another amazing build. All of the fuctionality built in is amazing, the detailing is over the top, the windshield is amazing. Not sure what is my favorite bit, but I do like how you did the leaf springs on the truks. Though one comment, your prototype photo shows the engine in later years, after removing the grill work on the sides, while your model is early years with the grills. Here's a photo closer to the as-built look. Quote
bogieman Posted June 11, 2022 Author Posted June 11, 2022 Thanks Zephyr! I do have a bit of a mashup of the as-built and modified versions. Originally, they were built with the air intakes all on the sides and none on the roof as I have but UP modified them to add the grilles on the top behind the cab and closed off many of the side grilles. I bought of bunch of 2x2 yellow tiles to modify the side grilles but haven't put them on yet, not sure I will as I don't find them very attractive. Dave Quote
zephyr1934 Posted June 12, 2022 Posted June 12, 2022 Oh yes, the as-new almost always looks way better than the in-service. As was the norm with locomotives, the as-new has all the pretty styling that looks amazing, and then over time, the crews that work on them slowly get their way and the purely decorative bits come off. The only point of my mentioning that is because your model is as-new but the example in the photograph of the actual locomotive in your first post is from later years after the decorative grills were removed. So someone who is not familiar with the turbines might go, "that one has grills but that one has squares." I'm all for the grills, I think it looks far more interesting. But yes, I didn't even think about that, the fuel tenders were added later, weren't they after the grills came off. I vote grills + tender Quote
bogieman Posted June 12, 2022 Author Posted June 12, 2022 This would have been a better picture to use for the prototype as it shows the grilles not yet blanked-off and no fuel tender. A fuel tender is on my list to build though. Quote
XG BC Posted June 12, 2022 Posted June 12, 2022 looks very nice! i like the yellow 3d printed cab piece more than the black one which you did before. Quote
Toastie Posted June 12, 2022 Posted June 12, 2022 Well, what to add? I just really admire the history, the stories, the photography, the knowledge behind all this - it makes a big difference to me. For me, your building skills are simply playing in another league. I really enjoy just seeing all that in LEGO world - as much as learning all the things you guy are providing here. Spoiler My group (many, many years before the pandemic and restarting in 2023) is regularly visiting the US for the annual ASMS meeting, usually held in major cities providing lodging for >7000 participants; Atlanta, Boston, Seattle, San Diego, Denver, Minneapolis, Houston, San Antonio, Los Angeles, and so on and so forth. We have a lot of fun, renting a house for 15+ folks in about one hour walking distance from the conference center (you go there >once< in the morning and then return - no crazy thinking about doing that again - and then, well, we party ). I usually look for the major train lines - and then spend some time there, just watching. San Diego is so cool: When 5 diesels pulling a train (indefinitely long) through the city, traveling past the conference center, man ... some folks get nervous - maybe thinking about never be able to cross that street again - to get some food. When I hear the bell - I slow down - to not being able to cross that very street. I like the sound of diesels. And I wish I could hear and see a gas turbine loco you modeled so nicely! All the best, Thorsten Quote
Feuer Zug Posted June 13, 2022 Posted June 13, 2022 A beast of a GTEL! You crammed all that power and equipment in the locomotive is phenomenal. Great work on the details too. Quote
zephyr1934 Posted June 13, 2022 Posted June 13, 2022 23 hours ago, bogieman said: A fuel tender is on my list to build Quote
bogieman Posted June 13, 2022 Author Posted June 13, 2022 (edited) 18 hours ago, XG BC said: looks very nice! i like the yellow 3d printed cab piece more than the black one which you did before. Thanks! This one took more iteration - the headlight bump made it more difficult to fit the window "glass" in, I did 12 test prints to get it in final form which isn't a perfect fit but close enough for me. 17 hours ago, Toastie said: Well, what to add? I just really admire the history, the stories, the photography, the knowledge behind all this - it makes a big difference to me. For me, your building skills are simply playing in another league. I really enjoy just seeing all that in LEGO world - as much as learning all the things you guy are providing here. Reveal hidden contents My group (many, many years before the pandemic and restarting in 2023) is regularly visiting the US for the annual ASMS meeting, usually held in major cities providing lodging for >7000 participants; Atlanta, Boston, Seattle, San Diego, Denver, Minneapolis, Houston, San Antonio, Los Angeles, and so on and so forth. We have a lot of fun, renting a house for 15+ folks in about one hour walking distance from the conference center (you go there >once< in the morning and then return - no crazy thinking about doing that again - and then, well, we party ). I usually look for the major train lines - and then spend some time there, just watching. San Diego is so cool: When 5 diesels pulling a train (indefinitely long) through the city, traveling past the conference center, man ... some folks get nervous - maybe thinking about never be able to cross that street again - to get some food. When I hear the bell - I slow down - to not being able to cross that very street. I like the sound of diesels. And I wish I could hear and see a gas turbine loco you modeled so nicely! All the best, Thorsten Thanks Thorsten! Compared to some of the steam loco builds I've seen, I'm pretty much middle of the road in building skills but appreciate the comments, diesel locos and their like are pretty simple by comparison. Yes, US railroading is quite different from the European practice, but when Siemens partnered with EMD in the early 90's on AC traction, it really jumped to another level. Climbing a grade at full throttle, 5 mph, is something to hear, see and feel. 2 hours ago, Feuer Zug said: A beast of a GTEL! You crammed all that power and equipment in the locomotive is phenomenal. Great work on the details too. Thanks! I have to give credit to the work by jepaz on Rebrickable (https://rebrickable.com/mocs/MOC-106723/jepaz/union-pacific-ge-8500-gtel/#details) for the nose shaping. Dave Edited June 13, 2022 by bogieman Quote
LEGO Train 12 Volts Posted June 13, 2022 Posted June 13, 2022 This work is totally cool ...and your layout is amazing with so many crossover! The sound from the locomotive is the icing on the cake! Quote
zephyr1934 Posted June 14, 2022 Posted June 14, 2022 22 hours ago, bogieman said: Thanks Thorsten! Compared to some of the steam loco builds I've seen, I'm pretty much middle of the road in building skills but appreciate the comments, diesel locos and their like are pretty simple by comparison. I too would say you are a great builder. Are you the best in the major league? Who knows, but you are in the major league so that makes you very good. Quote
bogieman Posted June 14, 2022 Author Posted June 14, 2022 On 6/13/2022 at 1:54 PM, LEGO Train 12 Volts said: This work is totally cool ...and your layout is amazing with so many crossover! The sound from the locomotive is the icing on the cake! Thanks Emanuele, once I added sound to the first loco, I had to have it on them all. Quote
Asper Posted June 14, 2022 Posted June 14, 2022 Wonderful model. It looks very accurate - and it can handle the tight LEGO curves. Sound and lights make it perfect. Great! Quote
LEGO Train 12 Volts Posted June 15, 2022 Posted June 15, 2022 11 hours ago, bogieman said: Thanks Emanuele, once I added sound to the first loco, I had to have it on them all. Oh yeah I know what that means Quote
Shiva Posted June 15, 2022 Posted June 15, 2022 Nice locomotive! At first, I almost read it as "steam turbine locomotive" :) Quote
Murdoch17 Posted June 15, 2022 Posted June 15, 2022 31 minutes ago, Shiva said: Nice locomotive! At first, I almost read it as "steam turbine locomotive" :) You know, UP did have a few of those type of locomotives delivered by GE in 1938! Anyway, great work on the Gas Turbines, @bogieman - I love that custom windscreen! Quote
Ropefish Posted June 16, 2022 Posted June 16, 2022 wonderful build, getting a lot of use out of that window piece! Quote
Dufflefan Posted June 19, 2022 Posted June 19, 2022 @bogieman This is a wonderful rendition of the real locomotive; my father loves trains so I've sent him the link to this post - I'm sure he'll be impressed! Quote
bogieman Posted June 21, 2022 Author Posted June 21, 2022 Thanks all for the positive feedback! Dave Quote
ivanlan9 Posted June 28, 2022 Posted June 28, 2022 Amazing! I've gotten to crawl over the one that used to be, and maybe still is, at Ogden Union Station here in Utah. Gotta admire the things, impractical as they were. I agree, bogieman, you're in the major leagues. Quote
