Our world needs superheroes...so let's make them stay!
Hi all! It has been some time since my last building, and here you go, the new Avengers Building!
After much controversy, the new building was finally permitted to be established and built in V City. Many people was too obsessed with the Stark-tower type of Avengers building, while I have another vision. The gradually slanting facade walls create an interesting elevation that looks different when you walk along. The idea of slicing up the building generates the dynamics for the blue-toned building, and at the same time creates privacy inside it with the folds.
The snow-cap like cladding is a gesture of destruction, peeling off to show the inner skin, and gives a contrast of solid and transparency. The four prominent vertical ridges gives a strong feeling of anchoring to the ground, going all the way to the top.
Due to the complex facade designs, the building opens up in the back to access the interior, which contains the lobby, war rooms, dormitory areas, equipment room, laboratory and storage spaces. Some areas are shielded from the windows due to privacy with interesting folds of walls.
The Iron Legion is always ready, for any identified or unidentified threats near the premises...
Yes, in this universe, we have both Captains and Iron Man...
"Monica, did you go to the wrong building? This is not your department..."
From bottom to top: the conference room, war room, dormitory area with restroom and kitchen, equipment room and storage, and the roof top.
Stop fighting on the roof and destroying my building, you two!
Top: What? Did you swallow it again? Bottom: Still fits, still...fits!
"Monica, again, this is not a place that you can just walk in. Restricted area! And sorry, white Vision is offline still..."
"I will see you in 5 seconds, okay?"
"Not the lifting hammer again. You know who can do it...not just you."
"If you're nothing without this suit, then you shouldn't have it, okay? God, I sound like my dad."
"Wrong universe but right timeline, huh, this is interesting."
"New enemies behind me...?"
Hope you like it! Now, the Avengers can assemble!
Very clean. I like the straight lines used. The little scenes/details really add a lot to the MOC as a whole. But even without the main figures it stands alone pretty well.
Thanks!
One of the most difficult challenges is to make sure everything is firm and tight with the rotated bases for each section of the buildings!
Wow, that is quite something!
I always love it when walls are not at 90 degree angles, and this is a perfect example of a great implementation of that.
Great attention to detail inside and out, and I love the general design of the building.
Keep clicking those bricks together!
Thanks Withacee! The non-90-degree walls are real challenges!
Quite the design. The external architecture is bold with the sloping section and the folds. Your internal details are great and really add to the building.
