Posted August 26, 20222 yr Hi to everyone, I want to introduce you my little Mod. 1969 Chevrolet Camaro SS 396 This is a modification of 10304 Chevrolet Camaro Z28 set. I really liked the original set, but I wanted an all black SS version for myself, so I made it. As soon as I saw the set, I immediately noticed the wrong angle of steering column and corrected it. LEGO keeps releasing 18+ sets with lots of visible parts in bright colors that I never liked. I tried my best to replace these parts with more suitable ones. And of course wide aggressive tires always look better :) I made high resolution instructions which exactly repeats steps numbers from original instructions, so you can easily compare if you want to. Obviously, some steps have a different number and colors of parts. Modifications include: - Steering column with better angle (more realistic) - Detailed door panels - Wide tires for a sportier look - Side markers - Exhaust pipes had to be replaced due to tire width - All visible bright colors are changed to black or dark grey - Tinted windshields, black grille, tiled floor, more realistic cups on wheels - Custom Vector Graphic stickers I made two PDFs (Stickers): A4 size for EU and Letter size for US. They need to be printed and cut by yourself. Instructions: https://rebrickable.com/mocs/MOC-121286/NikolayFX/1969-chevrolet-camaro-ss-396/#details Thank you! Edited August 26, 20222 yr by FX6000
August 27, 20222 yr This looks very good but I think the hood is too flat and makes the car look, not quite right.
August 27, 20222 yr Author 4 hours ago, Johnny1360 said: This looks very good but I think the hood is too flat and makes the car look, not quite right. It's square on all sides :) The hood has a slight angle, maybe 3mm
