As a birthday present for someone, I've built modified versions of two birds from Thomas Poulsom's Birds from Bricks.
I've generated instructions using the latest version of LEGO Studio and have a question about rendering an image to use on the cover:
Does anyone know what settings would result in the most LEGO-like rendering of a model? Meaning in terms of the images LEGO use on the covers of their own instruction manuals.
These are the settings I use for images for building instructions: PhotoReal
Render quality: medium, more is not nessessary
Background and light: Default and transparent  (transparent background lets you put the image on any background you choose)
                          Light: Mechanic and right front, I would try several to see what looks best for your subject. Change only one thing per try.
Device: GPU if you have good hardware!
Camera: default and perspective
Image size 1920 x 1080
Format: png 16 bit
Most of the time I'm doing Technic stuff so "mechanic" lighting may not be best for your application.
