gyenesvi Posted December 3, 2022 Posted December 3, 2022 2 minutes ago, GerritvdG said: The 7L beam is used in the 75533-1 Oh, I didn't follow that one, thanks. Is there anything else technic available besides the parts in 42099? Quote
GerritvdG Posted December 3, 2022 Posted December 3, 2022 Yes, the 42101, I've had quite some fun making alternatives of that set. The Bright Light Orange 2x4 liftarm is also pretty rare, only used in one Bionicle set (8755). Quote
SNIPE Posted December 3, 2022 Posted December 3, 2022 46 minutes ago, GerritvdG said: Yes, the 42101, I've had quite some fun making alternatives of that set. The Bright Light Orange 2x4 liftarm is also pretty rare, only used in one Bionicle set (8755). Yeah I only have 14 of them in orange Quote
gyenesvi Posted December 3, 2022 Posted December 3, 2022 1 hour ago, GerritvdG said: Yes, the 42101, I've had quite some fun making alternatives of that set. That's a nice one, those small panels could be useful! 17 minutes ago, SNIPE said: Yeah I only have 14 of them in orange Do you mean in Bright Light Orange? Quote
SNIPE Posted December 3, 2022 Posted December 3, 2022 (edited) 34 minutes ago, gyenesvi said: That's a nice one, those small panels could be useful! Do you mean in Bright Light Orange? Nah just regular orange, I though this set is normal orange and dark blue? Maybe I'm getting mixed up with flame yellowish orange (LDD) bright orange (LDD) orange (bricklink) and bright yellowish orange (bricklink). Edited December 3, 2022 by SNIPE Quote
R0Sch Posted December 3, 2022 Posted December 3, 2022 1 hour ago, SNIPE said: Nah just regular orange, I though this set is normal orange and dark blue? Maybe I'm getting mixed up with flame yellowish orange (LDD) bright orange (LDD) orange (bricklink) and bright yellowish orange (bricklink). This set is 100% in bright light orange (aka flame yellowish orange) and dark blue. Quote
Maaboo the Witch Posted December 3, 2022 Posted December 3, 2022 It's definitely bright light orange. Quote
GerritvdG Posted December 4, 2022 Posted December 4, 2022 On 12/2/2022 at 1:17 PM, Jundis said: This surely is a new connector, but couldn't it be done with a combination of these pieces: Wouldn't be that secure, as the axle is not secured as a pin, but do we really need a new part just for that solution? Applied this solution to the 42147 on my desk and it works flawlessly, better then the original. Maybe this solution doesn't meed TLG's standards, or they need some extra parts for the B-model. I don't understand for example why they've added the 5L liftarm to limit the steering range. This range is already limited by the steering linkage.... Quote
SNIPE Posted December 4, 2022 Posted December 4, 2022 (edited) I'm thinking about replacing the wheel arches with these: https://www.bricklink.com/catalogItemIn.asp?P=78666&colorID=110 Because the lego wheel arch plates that are 4L wide are too deep (2L) but it might mean moving the axle foward by 0.5L because currently the wheels centre points are aligned to a stud, not inbetween them by 0.5L. Edited December 4, 2022 by SNIPE Quote
Jundis Posted December 5, 2022 Posted December 5, 2022 22 hours ago, GerritvdG said: Applied this solution to the 42147 on my desk and it works flawlessly, better then the original. Maybe this solution doesn't meed TLG's standards, or they need some extra parts for the B-model. I don't understand for example why they've added the 5L liftarm to limit the steering range. This range is already limited by the steering linkage.... Dito. Only reason for the limited steering could be that the test audience (kids 7+) tipped the truck while steering too hard, so they limited the steering for bettter playability... Strangely, as a kid I remember loving that some toys had such great steering you didn't have to back up for tight corners. Quote
Zerobricks Posted December 5, 2022 Posted December 5, 2022 Maybe the 5L beam was needed for the B model and the designer just put it into the steering linkage. Quote
SNIPE Posted December 6, 2022 Posted December 6, 2022 (edited) I don't have any 78666 so I used a simular but too big part for the mudguards. The wheels are now 0.5 foward using the good ol' "axlehole with 4 pins" (32138) connector. And yes , the tipper is (for now) supporting the cabin.. I made the colors as close as possible with the parts I had. regards, Snipe Edited December 7, 2022 by SNIPE Quote
zagdima Posted December 7, 2022 Posted December 7, 2022 Very interesting, how this small set can provide so many speculations). New parts is always good i think this january we will have a lot of new parts, maybe more then last year. Quote
Void_S Posted December 9, 2022 Posted December 9, 2022 Some renders with custom parts installed: This new "Technic Pin Connector Perpendicular 3L with 2 Pins" (or however it will be officially called) may turn any liftarm into a flip-flop one. Like "Pin with a pinhole" does but with only one degree of freedom, that may be required in some situations. Quote
zoo Posted December 9, 2022 Posted December 9, 2022 4 hours ago, Void_S said: This new "Technic Pin Connector Perpendicular 3L with 2 Pins" (or however it will be officially called) may turn any liftarm into a flip-flop one. Like "Pin with a pinhole" does but with only one degree of freedom, that may be required in some situations. In the general part thread I wrote that I got disapointed for not being able to use the 7 x 11 frame to brace a 4-speed gearbox. This part could compliment those frames very nicly and solve that problem. Quote
SNIPE Posted December 10, 2022 Posted December 10, 2022 (edited) Finished! Here is 42147 my way I replaced the knobs with a beacon (steering) and a fake fuel drum (tipper) and added seats. I dont have the 1x2 half arch bricks so I used 1x2 curved slopes for the mudguards. And of course, I had to move the axle 0.5L forward using this part as a steering hub, so that the wheel would fit in the centre of the mudguards. I also added a tailgate that locks open or closed though it is a little heavy so gravity does not make it swing open and it is not in dark blue. I gave the tipper mechanism more friction so that it does not keep collapsing, and added opening doors. More photos here Regards, snipe Edited December 11, 2022 by SNIPE Quote
Paul B Technic Posted December 11, 2022 Posted December 11, 2022 This looks like a cool little set and a good base for some c models. Quote
Kostq Posted December 11, 2022 Posted December 11, 2022 Given that 42101 exists and has 117 parts for the same amount of money as this set - I'm a bit perplexed where does the TLC/TLG make money on these sets? Even looking at 42084 - this set has a lot of big pieces for such a small set /not counting 42044/. Quote
Polarlicht Posted December 21, 2022 Posted December 21, 2022 Also i wish they used the juniors/4+ whatever dual moulded wheels. They could have used the deep side for the rear axle and a star pattern for the front Quote
Void_S Posted December 21, 2022 Posted December 21, 2022 1 hour ago, Polarlicht said: Also i wish they used the juniors/4+ whatever dual moulded wheels. They could have used the deep side for the rear axle and a star pattern for the front Well, these wheels are already dual-molded, as they have "deep" and "spokes" sides: Quote
Polarlicht Posted December 21, 2022 Posted December 21, 2022 (edited) 1 hour ago, Void_S said: Well, these wheels are already dual-molded, as they have "deep" and "spokes" sides: I mean this wheel https://www.bricklink.com/v2/catalog/catalogitem.page?P=74214c01&idColor=86#T=C&C=86 , which has an even deeper side than the ones you show. And with dual moulded i mean the tyre is fixed on the rim on these. Edited December 21, 2022 by Polarlicht Quote
jorgeopesi Posted December 21, 2022 Posted December 21, 2022 12 hours ago, Polarlicht said: Here is the new connector I exactly know what I am going to do tomorrow with some old parts . Quote
Void_S Posted December 22, 2022 Posted December 22, 2022 16 hours ago, Repkovsky said: it looks like the designer still didn't decide if the doors should be a part of the cabin structure and keep its shape, or be openable... Quote
