Hello Ferrari and Speed Champions fans,
The Ferrari Daytona SP3 is a limited production mid-engine sports car produced by Italian automobile manufacturer Ferrari, unveiled on 20 November 2021 for the 2023 model year. The design references to 1960s race cars, it is a modernization of the 330 P4, with the body work consisting distinguished low driver's seating position, raised front and rear wheel arches, and the Targa top design. Building instructions are available on the following links:
https://rebrickable.com/mocs/MOC-131689/_TLG_/ferrari-daytona-sp3
https://www.mocsmarket.com/lego-mocs/ferrari-daytona-sp3/
It is a studless build in the new, 8 studs wide Speed Champions style. I wanted to create a sleek model which is as accurate as possible in this small scale. I prefer the brick built solutions to keep the flexibility of the used parts in further builds, and therefore only Ferrari logo and simple light gray head lights stickers are used.
My intent was to keep the width-length-height ratio of the real car and this size makes it possible. The model contains lots of details: for example the emblematic front and hood  grilles, the side and rear intakes, the side view mirrors etc... Maybe the most challenging one was the brick built narrow black and red lines on the front. I tried to fill every unnecessary gaps and therefore some tricky build techniques are used.
On the pictures the red grills on the front are connected only by half studs. However, if you prefer more sturdy models, then full connection is usable too, it is a bit less accurate, but looks decent too.
It is a very low build, an can roll well only on flat surfaces.
The model has space for two minifigures. I suggest to use helmets, or small hairs, and the upper part of the seats have to be removed in this case.
Thanks for visiting,
_TLG_
52563139363_31a428bc21_z.jpgFerrari Daytona SP3 - instructions 1 by László Torma, on Flickr
52562146567_8fb8f4ed91_z.jpgFerrari Daytona SP3 - instructions 2 by László Torma, on Flickr
52563139078_8cee4da03c_z.jpgFerrari Daytona SP3 - instructions 3 by László Torma, on Flickr
52562887514_fcfd6a20a8_z.jpgFerrari Daytona SP3 - instructions 4 by László Torma, on Flickr
52562601286_874d2822c0_z.jpgFerrari Daytona SP3 - instructions 5 by László Torma, on Flickr
52562887624_845ac99049_z.jpgFerrari Daytona SP3 - instructions 6 by László Torma, on Flickr
52563068610_29af71d96d_z.jpgFerrari Daytona SP3 - instructions 7 by László Torma, on Flickr
Edited by _TLG_
Mocsmarket link added
Stunning. You nailed this Ferrari. The use of the Technic panel for the door is ingenious and it works perfectly.
@Feuer Zug Thanks a lot! The technic panel was one of the first details when I was started to build this car :)
  • Rick featured this topic
