Timorzelorzworz Posted January 1, 2023 Posted January 1, 2023 To be onest, using new 2x5 to 2x3 corner panels in transclear for the headlights is a very neat idea. Quote
Void_S Posted January 1, 2023 Posted January 1, 2023 4 hours ago, Citromon said: It looks nice, but too many details are made with stickers, and when I think of Ford GT - is definitely not this model. It is Ford GT 2022 which is significantly different from the original one from 1964 ("Ford vs Ferrari" movie). The Lego set is not Ford GT'64 at all, for sure... Interesting, while I hate the new GT from 2022 (only '64 exists for me), I like this model! Quote
dhc6twinotter Posted January 1, 2023 Posted January 1, 2023 (edited) Apparently grohl designed this set. He did a great job one it! Edited January 1, 2023 by dhc6twinotter Quote
sm1995 Posted January 1, 2023 Posted January 1, 2023 I like it as a set, but from the front it doesn’t really look like a Ford GT to me. Looks more like a Maserati MC12 Quote
SNIPE Posted January 1, 2023 Posted January 1, 2023 (edited) So, I've been carefully spying on this set and ust look at the recolors and new parts!: New / returning recolors (inclusive of new parts): 1 x 1 x 1 Beam in dark blue {18654} [New] 1 x 2 x 3 Panel left in dark blue {2387} [New] 1 x 2 x 3 Panel right in dark blue {2389} [New] 1 x 2 x 3 Panel left in black {2387} [New] 1 x 2 x 3 Panel right in black {2389} 1 x 2 x 5 Panel left in dark blue {11947} (last seen in 2021) 1 x 2 x 5 Panel right in dark blue {11946} (last seen in 2021) 1 x 3 x 5 Parralelegram panel left in dark blue {80267} 1 x 3 x 5 Parralelegram panel right in dark blue {80268} 2 x 3 x 5 Panel left in dark blue {87080} (last seen in 2018) 2 x 3 x 5 Panel right in dark blue {87086} (last seen in 2018) 2 x 3 x 11 Curved panel smooth in dark blue {62531} 1 x 1 x 2 Comma panel in dark blue {89679} 1 x 2 x 3 Comma panel in dark blue {71682} 1 x 2 x 5 Curved panel extension in dark blue {80286} 1 x 3 x 7 Panel in dark blue {71709} 2 x 3 x 7 Curved panel in dark blue {24119} 2 x 3 x 11 Panel left in dark blue {64681} (last seen in 2018) 2 x 3 x 11 Panel right in dark blue {64393} (last seen in 2018) [New] 2 x 5 x 11 Rear wheel arch in dark blue {TBA} [New] 2 x 5 x 11 Front wheel arch in dark blue {TBA} 1 x x x 2 Pin with pinhole in dark blue {15100} 1 x 1 x 2 Axle with pinhole in dark blue {22961} 1 x 3 x 3 Biscuit joint in dark blue {39793} [New] 2 x 3 x 5 Left corner panel in trans clear {TBA} [New] 2 x 3 x 5 Right corner panel in trans clear {TBA} 0.5 x 1 x 2 Beam in dark blue {41677} (last seen in 2004) 1 x 1 x 2 Beam with axle hole in dark blue {60483} (last seen in 2020) 0.5 x 1 x 3 Beam in dark blue {6632} (last seen in 2004) 1 x 1 x 3 Beam in dark blue {32523} (last seen in 2020) 1 x 2 x 4 Beam bent in dark blue {32140} (last seen in 2022) 0.5 x 1 x 5 Beam with axle holes in dark blue {11478} 1 x 1 x 5 Beam in dark blue {32316} (last seen in 2020) 1 x 3 x 5 Bent beam in dark blue {32526} (last seen in 2020) 1 x 1 x 7 Beam in dark blue {32524} (last seen in 2020) 1 x 4 x 6 Beam bent diagonally in dark blue {6629} (last seen in 2020) 1 x 1 x 9 Beam in dark blue {40490} 1 x 1 x 2 Connector 1x2 in dark blue {6536} (last seen in 2004) 1 x 2 x 2 Connector open centre in dark blue {69819} 1 x 1 x 3 Connector #5 in dark blue {32015} 1 x 1 x 3 Bionicle tooth in dark blue {41669} 1 x 1 x 6.5 Shock absorber extra hard in Black {731c07} Possible re-released colors / returning rare colors: 1 x 1 x 11 Beam in dark blue {32525} (last seen in 2022) 1 x 1 x 13 Beam in dark blue {41239} (last seen in 2018) 1 x 1 x 15 Beam in dark blue {32278} (last seen in 2018) 2 x 3 x 6 Left panel in dark blue {64683} 2 x 3 x 6 Right panel in dark blue {64391} Note that some of the above information may be inforrect, but from the images at hand it looks to be pretty much on the money Edited January 4, 2023 by SNIPE Quote
astyanax Posted January 1, 2023 Posted January 1, 2023 Too bad they didn't manage to make 10197 in dark blue... (Under the headlight) Quote
jura93 Posted January 1, 2023 Posted January 1, 2023 If I see correct, this are the classic cylinder block bricks in transparent Quote
Lakop Posted January 1, 2023 Posted January 1, 2023 I'm looking at a ford GT calendar on my wall. The wheels need to be nearer to the wheel arch and the spoiler needs to be higher, again its lacking the aggressive muscle car look. if I had the money I would buy it just to try improve it. H Quote
TeriXeri Posted January 1, 2023 Posted January 1, 2023 (edited) Now just needs a Technic Jeremy Clarkson fig that barely fits, as he's known for his dark blue ford GT , and then someday have a Lambo Tractor set Edited January 1, 2023 by TeriXeri Quote
TechnicRCRacer Posted January 1, 2023 Posted January 1, 2023 29 minutes ago, jura93 said: If I see correct, this are the classic cylinder block bricks in transparent If so, that’s cool that they are including those in more realistic sets. It makes it easier to see the pistons move if the top of the blocks are covered or the engine is in a hard-to-see area. 16 minutes ago, TeriXeri said: Now just needs a Technic Jeremy Clarkson fig that barely fits, as he's known for his dark blue ford GT , and then someday have a Lambo Tractor set This makes me think, is this set roughly the same scale as the old Technic figures? Quote
Lemon Posted January 1, 2023 Posted January 1, 2023 1 hour ago, TechnicRCRacer said: This makes me think, is this set roughly the same scale as the old Technic figures? No, technic figures are approximately 1:20. Quote
NoEXIST Posted January 2, 2023 Posted January 2, 2023 12 hours ago, Jurss said: I rechecked, and it seems, that with these wheels width would be ~23L. Maybe counted wrong, or there finally is some axle with specific end, that can be connected to something, that goes in to differential? Also counted it several times, but always got 21 studs. I was counting by the front end of the car and also by it's spoiler... I wonder if they should rather use new parts for it or floating diff suspension. Quote
deehtha Posted January 2, 2023 Posted January 2, 2023 (edited) Given that the description says 18cm width, that works out to 22.5 studs. So, 23 studs is probably the width. I count 21 studs wide as well. It looks like the mirrors extend out past the body another 1 stud on each side, 23 studs wide. Edited January 2, 2023 by deehtha Counted studs instead of just doing math. Quote
Jurss Posted January 2, 2023 Posted January 2, 2023 And wheels also doesn't seem to be much out of wheelarches, or also suspension is not so much up, so that there could be one stud more. So, there is small hope :D Quote
dabo Posted January 2, 2023 Posted January 2, 2023 What other car sets is this the same scale as? Quote
LvdH Posted January 2, 2023 Posted January 2, 2023 10 minutes ago, dabo said: What other car sets is this the same scale as? Dom’s Charger, “The Batman” Batmobile and Ford Raptor. Quote
NoEXIST Posted January 2, 2023 Posted January 2, 2023 6 hours ago, deehtha said: Given that the description says 18cm width, that works out to 22.5 studs. So, 23 studs is probably the width. I count 21 studs wide as well. It looks like the mirrors extend out past the body another 1 stud on each side, 23 studs wide. It seems to me you forgot about rearview mirrors Quote
gyenesvi Posted January 2, 2023 Posted January 2, 2023 9 hours ago, NoEXIST said: Also counted it several times, but always got 21 studs. I wonder if they should rather use new parts for it or floating diff suspension. Are you guys saying that at this body width the suspension needs to be 15 studs wide, at which it would not be possible to build a driven independent suspension with current joints, only with a floating differential, which may not be the way to go in an official set so we are hoping for new CV joints that would allow for narrower suspension? :) I am really holding my breath for this, because I figured that the upcoming Audi may also need such a setup for its (hopefully driven) front independent suspension, which may also need to be 15 wide with buggy wheels.. Quote
NoEXIST Posted January 2, 2023 Posted January 2, 2023 5 minutes ago, gyenesvi said: Are you guys saying that at this body width the suspension needs to be 15 studs wide, at which it would not be possible to build a driven independent suspension with current joints, only with a floating differential, which may not be the way to go in an official set so we are hoping for new CV joints that would allow for narrower suspension? :) I am really holding my breath for this, because I figured that the upcoming Audi may also need such a setup for its (hopefully driven) front independent suspension, which may also need to be 15 wide with buggy wheels.. Sort of, any single way to create this suspension with currently available parts is not in lego style. I am personally waiting for something like this: Also to be honest, I will be happy even without these parts, at least it should be interesting to build :) Quote
gyenesvi Posted January 2, 2023 Posted January 2, 2023 1 minute ago, NoEXIST said: I am personally waiting for something like this Exactly, that's what I am waiting for as well! Though it would be great to have a variant of this with the newer CV joint with a 2L axle on both the female and the male part (but this older one would be interesting and better than nothing as well, those Cada ones have 2.5L axles if I'm not mistaken). Quote
dabo Posted January 2, 2023 Posted January 2, 2023 2 hours ago, LvdH said: Dom’s Charger, “The Batman” Batmobile and Ford Raptor. Thank you suspected it was different from the sets I have. Quote
NoEXIST Posted January 2, 2023 Posted January 2, 2023 Here it is! There is definitely something new. Quote
msk6003 Posted January 2, 2023 Posted January 2, 2023 (edited) 4 hours ago, NoEXIST said: Or TLG make 2L CV joint which has male part on both end. I hope shorter suspension arm/shorter link come in here. Edited January 2, 2023 by msk6003 Quote
1gor Posted January 2, 2023 Posted January 2, 2023 2 minutes ago, msk6003 said: Or TLG make 2L CV joint which has male part on both end. I hope shorter suspension arm/shorter link come in here. something like that definitely since TLC used thin 6L liftarms for independent suspension before Quote
