I accidentally used the wrong kind of 1x2 tiles in a large moc.  Replacing almost 400 of them from 1x2 tile without groove to 1x2 tile with grove would take a while, and the tiles without groove doesn't exists in tan.  Is there a way to batch swap all tiles to the correct type?  Like opening the file with text editor and use find & replace all 3069a to 3069b?
I know I managed to do that in LDD by searching and replacing an ID. Might be worth a try opening the studio file with a notepad or such and try?
Edited by Zerobricks
Hi,
You can use the Replace tool.
Note though that it only works in the current submodel.  So you’ll either need to do it for every submobel one by one.
Or you can export to LDraw, edit the (text) file in an editor, and then re-import.
