After Wayne Manor is destroyed in Batman Begins (2005), the Batcave is out of commission and under construction during The Dark Knight (2008). The Batcave is transformed from a dark lair to a high-tech research lab with concrete walls and a bright geometric ceiling. The backup Batcave is located underground in Gotham City along the riverfront. The spartan accommodations are accessed via a lift hidden within a set of shipping containers.
This MOC will take advantage of the limited source material and visuals from The Dark Knight. This MOC will be built out in sections with updates posted periodically online.
The first phase was to start with the central lift area that allows the Tumbler to enter and exit the Batcave. The LEGO® DC Batman™ Batmobile™ Tumbler: Scarecrow™ Showdown set was built and modified first. The next step was to build a partially raised lift that will come up from the floor. Custom printed steel floor plate tiles were used along with some standard LEGO tiles and pieces.
As always, your feedback and comments are always welcomed.
