Stereo Posted June 29, 2024 Posted June 29, 2024 A thin liftarm with half-offset axle holes at one end would be nice to have. Like the cam piece but not 2 studs wide. Maybe 5 long with 3 pinholes, then 3 axleholes overlapping. Quote
gyenesvi Posted June 29, 2024 Author Posted June 29, 2024 (edited) 4 hours ago, 1gor said: Today I was praying for exactly that part... Maybe I heard it :D 3 hours ago, astyanax said: I'm quite sure I was already arguing in favor of exactly this part on the first page or so. Better later than never :D Sorry for being slow.. Not that this render would change much about the situation.. 1 hour ago, Stereo said: A thin liftarm with half-offset axle holes at one end would be nice to have. Like the cam piece but not 2 studs wide. Maybe 5 long with 3 pinholes, then 3 axleholes overlapping. Indeed, that one as well. I guess even a 2L version with 3 axle holes would be doable based on the cam piece, though may be too weak.. Edit: just realized that a 2L version with 3 axle holes would be pointless; it's impossible to insert two axles with 0.5 spacing. So the shortest meaningful one would be 2.5L (kind of too similar to existing 2L). In case of overlapping axle holes, some reinforcement seems necessary, like in case of the cam piece (wider around the axle holes). Edited June 29, 2024 by gyenesvi Quote
Stereo Posted June 29, 2024 Posted June 29, 2024 37 minutes ago, gyenesvi said: In case of overlapping axle holes, some reinforcement seems necessary, like in case of the cam piece (wider around the axle holes). Yeah, the way parts like the 24t gear have been modified over the years (getting rid of its diagonal axle holes) makes me think they're more cautious of parts that can break into small pieces now. So maybe more viable is something like a 2.5 or 3.5 stud beam with axle holes at both ends and nothing in the middle. Quote
1gor Posted June 30, 2024 Posted June 30, 2024 5 hours ago, gyenesvi said: Maybe I heard it :D Well, you're not that far away Quote
howitzer Posted June 30, 2024 Posted June 30, 2024 12 hours ago, Stereo said: A thin liftarm with half-offset axle holes at one end would be nice to have. Like the cam piece but not 2 studs wide. Maybe 5 long with 3 pinholes, then 3 axleholes overlapping. I've been wanting for a long time more parts for making half-stud offsets and something like this along with the forementioned 4-pinholes+axlehole part would be greatly useful. The current selection of such parts are much too restricted in the ways they allow connections. Quote
msk6003 Posted June 30, 2024 Posted June 30, 2024 While building my TC27 entry, I find I need this kind of beam. Quote
NV Lego technic Posted June 30, 2024 Posted June 30, 2024 I'd love to see a 3l beam with axles on ends. Also, all of suspension wishbone variations seem very cool and I'd definitely find this useful, but untill then we have to resort to using old ungeared hubs and weak CV joints. Also a universal joint that has an axle on one end and is "normal" on the other would be a good part for 9 and 7 stud wide driven and steered axles, and 11 stud axles with diffs. Then, a 20t double bevel lockable differential would be cool, as it would de easier to protect it from grass (my models love it) and you could fit it inside of a 5 x 7 frame with a 2l driving ring and have a compact lockable diff setup. The only problem would be powering it inside of that setup. Although I don't have access to studio right now, so maybe there are some gear combinations. Quote
HorcikDesigns Posted June 30, 2024 Posted June 30, 2024 I was always (since learning what it is, with some pauses of course) dreamed of some proper Tatra suspension parts, so I finally tried to think of how it could look like. You can 3D print them too, if you would like. ;)https://makerworld.com/en/models/513453#profileId-429560 I know, the thing on the picture has only axles and axle connectors (and hidden liftarm) made by LEGO. But I would find very useful the 22t module 2 gear with axle hole. :) Quote
1gor Posted June 30, 2024 Posted June 30, 2024 @HorcikDesigns I wpuld be glad if there would be possibility to have 20 tooth double bevel gear for differentoal housing to incorporate smaller differential in Tatra type suspension Quote
HorcikDesigns Posted June 30, 2024 Posted June 30, 2024 @1gor@1gor well, that would be very good paet, but it would require 0.5 module (or smaller) gears. I have them prepared, but making reduction to lego axle will be tricky. All at all, fit coaxial differential into 24mm (3 studs) and make 5mm (diameter of axle) reduction will be quite a challenge. :D Quote
1gor Posted June 30, 2024 Posted June 30, 2024 52 minutes ago, HorcikDesigns said: @1gor@1gor well, that would be very good paet, but it would require 0.5 module (or smaller) gears. I have them prepared, but making reduction to lego axle will be tricky. All at all, fit coaxial differential into 24mm (3 studs) and make 5mm (diameter of axle) reduction will be quite a challenge. :D I know buddy; that is giving me headachse for some time for my Syntrac...if you remember that I made 21 stufs wide Tatra axle inclooding Unimog tires ...now 17 or 19 studs wide inclooding Zetros tires is my challenge 1 hour ago, HorcikDesigns said: @1gor@1gor well, that would be very good paet, but it would require 0.5 module (or smaller) gears. I have them prepared, but making reduction to lego axle will be tricky. All at all, fit coaxial differential into 24mm (3 studs) and make 5mm (diameter of axle) reduction will be quite a challenge. :D If you asked me, I'll be satisfied with that kind of gear arangement... Quote
Stereo Posted June 30, 2024 Posted June 30, 2024 (edited) I have thought about a smaller diff design, probably 24t ring, but never got to building a 3d model for it. It might work with the usual 'axle hole on an undersize bar' but probably 12t bevel with pinhole would be helpful to making it structurally sound. 1st piece is loose bar (or pinhole) sized stubs for mounting the planets, you'd put an axle with stop through from the middle into the 12t bevel on one side. 2nd piece is a 24t gear with a 1 stud wide crosspiece through the middle, with pinhole, and gaps for the bevel gears. So an axle with stop goes through it the other way into the other 12t bevel. The two fit together like lincoln logs and are fit in between beams so everything's captive. Wouldn't be as strong as a one-piece diff but for the kind of small construction that wants a narrow diff it'd be fine. It might be possible to have the bars for the planet gears overlong and clip into the ring gear, but I'd need a dimensionally accurate 3d model to decide about that. Edited June 30, 2024 by Stereo Quote
gyenesvi Posted June 30, 2024 Author Posted June 30, 2024 (edited) 10 hours ago, msk6003 said: While building my TC27 entry, I find I need this kind of beam. I think this kind of beam would unfortunately be too weak at the point where the 3 overlapping axle holes are.. 9 hours ago, HorcikDesigns said: I was always (since learning what it is, with some pauses of course) dreamed of some proper Tatra suspension parts, so I finally tried to think of how it could look like. You can 3D print them too, if you would like. ;) Oh, that's a very neat design! Quite specialized, but not more than the fenders of the lunar rover :) 8 hours ago, 1gor said: @HorcikDesigns I wpuld be glad if there would be possibility to have 20 tooth double bevel gear for differentoal housing to incorporate smaller differential in Tatra type suspension 5 hours ago, Stereo said: I have thought about a smaller diff design, probably 24t ring, but never got to building a 3d model for it. It might work with the usual 'axle hole on an undersize bar' but probably 12t bevel with pinhole would be helpful to making it structurally sound. I have also been thinking about smaller, 20T differentials, that would be kind of a holy grail for live axles, because they could become smaller in multiple dimensions which would reduce bulkiness a lot and make space for other things like steering linkages and panhard rods. There's a 3d-printable 20T differential housing (2 studs wide) and tiny gears to inside designed by Efferman, I have them printed, so it's doable. The only problem with it is that it requires a 12T gear on a 2.5 stud axle to drive it, which would probably have to be a single piece then, and then only a U-joint can be connected to it on the other side, no CV joint. Still it could work, but needs some specialized parts. I think the best way to make that would be a pre-built, enclosed diff housing with tiny gears inside made from some stronger material, something akin to the planetary hub. And then a 5x5 diff frame could be made for it.. So not quite the generic parts that I'm aiming for in this thread, but yeah, would be a game changer. @Stereo I'm not really able to follow you with these drawings.. I especially don't get the 24T or 28T gear, because the point would be to fit into 3 studs (right?), and those don't. Edited June 30, 2024 by gyenesvi Quote
Stereo Posted June 30, 2024 Posted June 30, 2024 10 minutes ago, gyenesvi said: @Stereo I'm not really able to follow you with these drawings.. I especially don't get the 24T or 28T gear, because the point would be to fit into 3 studs (right?), and those don't. 24 can't, but it's possible to use the space 2 studs away for parts shaped like axle/pin perpendicular connector's axle end (6536, 42003, 32068). Though interestingly that only applies to some 24T gears, I ran into a problem with a MOC once when I used the wrong variant of 3648b - some have flattened tips of teeth, some are rounded and can't do this. I'll have better 3d tools later in the week for measuring this stuff, I'm wondering if a 20t would work if you basically design it as slots in the outer housing of the diff that a non-bevel can dig into. Or if those teeth get all the way into the 12t bevels inside the diff. Quote
gyenesvi Posted June 30, 2024 Author Posted June 30, 2024 3 minutes ago, Paul B Technic said: This but 4L That's already on the list on the first page. And you can buy it from Cada, I have them. Quote
Paul B Technic Posted June 30, 2024 Posted June 30, 2024 1 hour ago, gyenesvi said: That's already on the list on the first page. And you can buy it from Cada, I have them. Thanks, I had not seen that. I might have to get some. Quote
Erik Leppen Posted July 3, 2024 Posted July 3, 2024 On 7/1/2024 at 12:05 AM, Paul B Technic said: This but 4L Use two normal black pins and a 4L bar. Really, bars are the most underrated pieces in Technic, as they fit into both pins and axleholes, and even allow the axlehole connection to be rotated. Quote
SNIPE Posted July 3, 2024 Posted July 3, 2024 I agree that you can sort of join 2 pins together using a bar , and that bars are useful, but a 4L friction pin would still be more reliable. Quote
NV Lego technic Posted July 4, 2024 Posted July 4, 2024 9 hours ago, Erik Leppen said: Use two normal black pins and a 4L bar. I also use this solution a lot in my MOCs. Quote
msk6003 Posted July 10, 2024 Posted July 10, 2024 Congratulation guys. There is 12t clutch gear on mclaren. Quote
Zerobricks Posted July 10, 2024 Posted July 10, 2024 Just wish they would design it so it can also mesh with combined spur/bevel gears... Quote
NV Lego technic Posted July 10, 2024 Posted July 10, 2024 Or have a separate extension ring so it could be used to spin Independent from the axle it sits on. Quote
gyenesvi Posted July 10, 2024 Author Posted July 10, 2024 3 hours ago, msk6003 said: Congratulation guys. There is 12t clutch gear on mclaren. Yeeeaaah! Even though I don't think this thread has influenced anything, this part / the whole gearbox was probably being already designed when that gear was proposed, but I am quite happy that this happened, and that it's kind of the form that we predicted. Excited to see how it can be used in compact RC gearboxes. 2 hours ago, NV Lego technic said: Or have a separate extension ring so it could be used to spin Independent from the axle it sits on. Not sure if that is physically possible, but interesting idea! Quote
