It began with @mcphatty's excellent mod for this set (check it out on his rebrickable if you're interested). Adding the inner wing pylons really helped, as well as some of the more minor changes he made. I was still unhappy though, and wanted to push for further accuracy.
First up was some minor colour changes of pieces, mainly removing any dark bley, replacing it with either light bley or black, where appropriate.
I ended up figuring a solution for the famous inset "exhaust" at the back of the cockpit - although this shape is sometimes referred to as a window or hatch instead. Regardless, I managed to capture the shape pretty well and am happy with how that turned out.
Next was a slight change to the "arms" that connect the cockpit to the wings - I ended up reverting some of ron_mcphatty's changes, so it became a blend of the set, and his mod.
The biggest change of all came in the form of the cockpit and it's interior - taking inspiration from the @BrickVault / @Jerac model, I changed up the controls. I then added the dark bley paneling at the front of the cockpit window, something which has been omitted from almost every version of TIE Fighter I've seen. I like to call it a dashboard.
Overall I'm quite happy with this mod, although I still think it could be improved further in future... Maybe one day. Also happy to take suggestions if there is anything you want to point out for me to fix/change!
The model, built and rendered in studio. They aren't the latest renders, and have not been updated with the dashboard in the cockpit interior.
The dashboard on the interior of the cockpit viewport. It just fits and allows the window to close 99% fully.
Reference photo of an original studio model. Visible is the dashboard.
