Ngoc Nguyen Posted February 23, 2023 Posted February 23, 2023 Price: 170-180$ Piece count: 1492 pieces Description: Give John Deere fans an unforgettable experience and invite them to recreate every detail of one of the famous manufacturer's biggest machines. Engineering and farming enthusiasts aged 11+ will love learning about the many authentic features of the LEGO® Technic John Deere 948L-II Skidder (42157) including steering, 4WD and a running engine . They will also observe the pneumatic functions which, like on the real skidder, operate the 3 movements of the gripper, the blade and the rotating seat. The LEGO Builder app offers an intuitive building experience: kids can zoom, rotate 3D models, save sets and track their progress. This LEGO® Technic building set measures over 8” (21cm) high, 21” (53cm) long and 7” (19cm) wide. More info coming soon. Quote
allanp Posted February 23, 2023 Posted February 23, 2023 Oooooh, that sounds very much like there's 5 pneumatic functions! Quote
Jundis Posted February 23, 2023 Posted February 23, 2023 5 hours ago, Ngoc Nguyen said: They will also observe the pneumatic functions which, like on the real skidder, operate the 3 movements of the gripper, the blade and the rotating seat. 1 hour ago, allanp said: Oooooh, that sounds very much like there's 5 pneumatic functions! Could also meant in a way, that the gripper has 3 pneumatic functions and the others are just manual. To turn the seat with pneumatic doesn't make any sense to me :D IF the blade is lifted with pneumatics, I wonder if the little 5L cylinders are sufficient or we get a return of these, maybe in DBG: Quote
Jurss Posted February 23, 2023 Posted February 23, 2023 Maybe they have now pneumatic rotator? It could be used also for claw operation. Quote
allanp Posted February 23, 2023 Posted February 23, 2023 16 minutes ago, Jurss said: Maybe they have now pneumatic rotator? It could be used also for claw operation. I did think that also (didn't want to mention it incase it lead to disappointment!) like if there's some new rotary pneumatic actuator (not continuous like a motor, but like 180 degrees or 270 degrees of rotation) it would make more sense of the description. It says three movements of the gripper, but on the real one, one of the three movements is the rotation of the claw. So if they have one there I guess why not add one for the seat also? So it would make more sense of the description but I don't want to get anyone's hopes up. I must not be disappointed if there is no new rotary actuator, only very very happy if there is one. Quote
Akbalder Posted February 23, 2023 Posted February 23, 2023 3 hours ago, allanp said: Oooooh, that sounds very much like there's 5 pneumatic functions! I think that it must be read: They will also observe - the pneumatic functions which, like on the real skidder, operate the 3 movements of the gripper - the blade - rotating seat Quote
1gor Posted February 23, 2023 Posted February 23, 2023 8 hours ago, Ngoc Nguyen said: LEGO® Technic building set measures over 8” (21cm) high, 21” (53cm) long and 7” (19cm) wide That indicates usage of 107mm tires since real machine is 3.5m wide Quote
jorgeopesi Posted February 23, 2023 Posted February 23, 2023 But the gripper has four movements, isn´t it?, I do not know if the gripper turns free or not. Quote
Saruzeufel Posted February 23, 2023 Posted February 23, 2023 3 hours ago, allanp said: on the real one, one of the three movements is the rotation of the claw 9 minutes ago, jorgeopesi said: I do not know if the gripper turns free or not. Nope, it can move: 1) up/down, 2) forwards/backwards and 3) claw open/closed. These claws usually only have a "return to center" function to some degree or none at all for rotation. Quote
jorgeopesi Posted February 23, 2023 Posted February 23, 2023 3 hours ago, Saruzeufel said: Nope, it can move: 1) up/down, 2) forwards/backwards and 3) claw open/closed. These claws usually only have a "return to center" function to some degree or none at all for rotation. Thanks, I thought it had some rotation to orient the gripper. Quote
Maaboo the Witch Posted February 23, 2023 Posted February 23, 2023 Nice to see TLG keeping the tradition of pneumatic forestry equipment alive as well! Quote
R0Sch Posted February 23, 2023 Posted February 23, 2023 Hope it will be in the same league as the Claas Xerion and won't be a LEGO exclusive set again like the smaller JD tractor. I guess we can forget about double wheels... Quote
Maaboo the Witch Posted February 24, 2023 Posted February 24, 2023 11 hours ago, R0Sch said: Hope it will be in the same league as the Claas Xerion and won't be a LEGO exclusive set again like the smaller JD tractor. I guess we can forget about double wheels... Actually, the 9R is widely available in the UK as of now, so you might want to sit tight. Quote
Jundis Posted February 24, 2023 Posted February 24, 2023 14 hours ago, R0Sch said: I guess we can forget about double wheels... Hmm but would be fun to mod it into a 768L-II: Quote
gyenesvi Posted February 24, 2023 Posted February 24, 2023 1 hour ago, Jundis said: Hmm but would be fun to mod it into a 768L-II: Wow, I like this version, it could be a great candidate for a mix of large and medium tractor tires Quote
1gor Posted February 24, 2023 Posted February 24, 2023 14 minutes ago, gyenesvi said: Wow, I like this version, it could be a great candidate for a mix of large and medium tractor tires I'm affraid medium size (81mm) is to small to maintain correct proportions... Quote
allanp Posted February 24, 2023 Posted February 24, 2023 (edited) 23 hours ago, Saruzeufel said: Nope, it can move: 1) up/down, 2) forwards/backwards and 3) claw open/closed. These claws usually only have a "return to center" function to some degree or none at all for rotation. I'm not sure I follow. The description says 3 movements and claw and seat rotation. To me that reads as 1) up/down 2) forwards/backwards 3) rotation and then we have claw open/closed and seat. But descriptions have been inaccurate before. Descriptions from promobricks tend to be more reliable though, so I wonder what they will say of it. Edited February 24, 2023 by allanp Quote
TechnicSkiier802 Posted February 24, 2023 Posted February 24, 2023 54 minutes ago, 1gor said: I'm affraid medium size (81mm) is to small to maintain correct proportions... If it was the 6 wheeled bogie skidder version I think ithe proportions would work for the front wheels. The description already confirmed its 4x4 though. May be an interesting mod though. Quote
1gor Posted February 24, 2023 Posted February 24, 2023 11 minutes ago, TechnicSkiier802 said: If it was the 6 wheeled bogie skidder version I think ithe proportions would work for the front wheels. The description already confirmed its 4x4 though. May be an interesting mod though. Well, it is a compromise...on those skidders front tires are 30.5-32 (1877mm diameter) and rear are 780/50-28.5 (1525mm diameter) specifications are here: https://www.deere.com/assets/pdfs/common/products/skidders/msk768liiu-768l-ii-bogie-skidder.pdf front tires: https://www.heuver.com/product/b30500032fi26for00/30-5l-32-firestone-forestry-sp-26pr-tl rear tires: https://www.heuver.com/product/b78050285noa8ff200/780-50-28-5-nokian-forest-king-f2-sf-182a8-190a2-24pr-tt Quote
Saruzeufel Posted February 24, 2023 Posted February 24, 2023 On 2/23/2023 at 5:08 AM, Ngoc Nguyen said: the 3 movements of the gripper 1 hour ago, allanp said: The description says 3 movements and claw It says 3 movements OF (not AND) the gripper. But I agree, let's wait for pictures or at least a proper description. Quote
Maaboo the Witch Posted February 25, 2023 Posted February 25, 2023 Wonder if any of the green parts from Dragon will be reappearing in this set. Quote
1gor Posted February 26, 2023 Posted February 26, 2023 8 hours ago, Maaboo35 said: Wonder if any of the green parts from Dragon will be reappearing in this set. 7 studs long beam with alternate holes ... Quote
Maaboo the Witch Posted February 27, 2023 Posted February 27, 2023 For anyone who isn't familiar with this 🐕, here it is again... ...and I am wondering how this model is gonna use the V2 pneumatic cylinders without being utterly mahoosive. Quote
Jockos Posted February 27, 2023 Posted February 27, 2023 (edited) 12 minutes ago, Maaboo35 said: For anyone who isn't familiar with this 🐕, ...and I am wondering how this model is gonna use the V2 pneumatic cylinders without being utterly mahoosive. Maybe it will introduce a new cylinder. Actually, I would be surprised if it included a new tire, too. Edited February 27, 2023 by Jockos Quote
Maaboo the Witch Posted February 27, 2023 Posted February 27, 2023 3 minutes ago, Jockos said: Maybe it will introduce a new cylinder. Actually, I would be surprised if it included a new tire, too. Either or both would make sense. Quote
