msk6003 Posted June 12, 2023 Posted June 12, 2023 45 minutes ago, SNIPE said: And watch out 2L pin which connect 3x3 biscuit and 5x7 frame. When I disassembly mine, those pin is little bent. Quote
Ngoc Nguyen Posted June 29, 2023 Author Posted June 29, 2023 (edited) Soon. Edited June 29, 2023 by Ngoc Nguyen Quote
Johnny1360 Posted June 29, 2023 Posted June 29, 2023 On 6/12/2023 at 4:53 AM, msk6003 said: And watch out 2L pin which connect 3x3 biscuit and 5x7 frame. When I disassembly mine, those pin is little bent. If you mean the common black pins 2m with friction, those come pre-bent from the factory. Something that seems to bother no other person than me. 😂 Quote
M_longer Posted June 30, 2023 Posted June 30, 2023 On 6/29/2023 at 6:10 AM, Ngoc Nguyen said: Soon. How does the tilting of the bucket works? And where's rear arm? ;) Quote
Ngoc Nguyen Posted June 30, 2023 Author Posted June 30, 2023 14 minutes ago, M_longer said: And where's rear arm? ;) 42157's biggest tragedy is that it has enough functional parts (cylinders, etc) for a backhoe but not enough structural parts for it. Quote
msk6003 Posted June 30, 2023 Posted June 30, 2023 On 6/12/2023 at 9:38 AM, msk6003 said: My first 42157 john deere 948L alternative - Backhoe loader I use almost every black 2L pin in this set. Function L6 engine with cooling fan which drive 4x faster than rear wheel(RWD) Front wheel steering Rear hoe turning by yellow knob on top of cabin Axle 2 and bucket on rear work by 2 mini linear actuators Direction changeable driver seat Manual outrigger which can lift back wheel Openable hood Both 2 axle of main bucket work using pneumatic Axle 1 of rear bucket work by pneumatic too That's a lot of function. Isn't it? And I usually don't build vehicle like this. This is my FIRST backhoe loader build. Before one page I did it. But my model's front bucket is to small compare to whole vehicle. Quote
Ngoc Nguyen Posted June 30, 2023 Author Posted June 30, 2023 (edited) Yes I did see that post and yes it can be turned into a backhoe, but what i meant was that there is not enough parts to turn it into the backhoe I'd be satisfied with and be proud of showing. Edited June 30, 2023 by Ngoc Nguyen Quote
Ngoc Nguyen Posted July 28, 2023 Author Posted July 28, 2023 On 6/30/2023 at 2:49 PM, M_longer said: How does the tilting of the bucket works? Manually moving the bar here. The bucket is held in place thanks to friction. Quote
msk6003 Posted February 14, 2024 Posted February 14, 2024 I finish to make instruction of my backhoe. Function Straight 6L engine and working cooling fan connected on rear wheel with 1:4 gear acceleration Steering with HOG Openable bonnet Poistion changeable seat Manual outrigger Pneumatic front bucket tilting Pneumatic front bucket lifting Pneumatic rear main arm lifting Rear arm turning with HOG Working rear second arm Working rear bucket Quote
R0Sch Posted February 20, 2024 Posted February 20, 2024 Wow! Nice alternative. Looks cool too. I would suggest to use "black rubber" for the wheels as a color though. @msk6003 Quote
msk6003 Posted February 20, 2024 Posted February 20, 2024 2 hours ago, R0Sch said: Wow! Nice alternative. Looks cool too. I would suggest to use "black rubber" for the wheels as a color though. @msk6003 Very thanks! Quote
anyUser Posted February 27, 2024 Posted February 27, 2024 On 5/7/2023 at 9:51 AM, kbalage said: After quickly checking the small John Deere tractor I would say the shade of green on the stickers should be more or less ok, I don't think TLG updated anything between these two models just to make it worse. I did a check using a RAL colour fan as reference: (Dark) green brick colour (from set 42157) doesn't match any of the "pure" colours shown there. Closest ones are RAL 6032 (Signal green) respectively RAL 6024 (Traffic green) The basic green on the sticker set of 42157 actually is comprised of thin lines in two different shades of green. I did not take any effort to resolve them. The overall impression again is not a single coulour. It could be best described as RAL 6029 (Mint green) respectively RAL 6001 (Emerald green). Interestingly, John Deere-green also is not a pure colour in RAL scheme. It has been attributed as RAL 6002 (Leaf green) or RAL 6010 (Grass green). [RAL 6032 is also mentioned but I could find that in any second source). Does anyone with any two of 42136, 42157, 42168 can compare if the basic green of the stickers is of the same hue? Remark: I compared colour under artificial light: a) fluorescent lamp b) LED warm tone Quote
1gor Posted March 11, 2024 Posted March 11, 2024 I don't know if someone noticed Self propelled Sprayer as alyernative model. It is a bi wobble, but intersting alternative... https://youtu.be/ME-uKiENTpQ?si=dL-L1Lt0I1YcuUW- Quote
