TexasEngineer454 Posted May 2, 2023 Posted May 2, 2023 Hard to tell from the pictures I've seen online, but does anyone have an idea of tire size? I'm guessing same 107x44r as the 42054? Honestly if it comes in under $200USD I'm getting it. Lots of pneumatics and if it really has 4 hubs and all of the gears and such to move the claw it'll be worth it for me. Better pieces than the new Volvo 42081 too. Quote
Maaboo the Witch Posted May 2, 2023 Posted May 2, 2023 3 minutes ago, TexasEngineer454 said: Hard to tell from the pictures I've seen online, but does anyone have an idea of tire size? I'm guessing same 107x44r as the 42054? The very same. Last set to use them was 42099 in 2019, so it's been a while. Quote
Repkovsky Posted May 2, 2023 Posted May 2, 2023 34 minutes ago, TexasEngineer454 said: Hard to tell from the pictures I've seen online, but does anyone have an idea of tire size? I'm guessing same 107x44r as the 42054? Honestly if it comes in under $200USD I'm getting it. Lots of pneumatics and if it really has 4 hubs and all of the gears and such to move the claw it'll be worth it for me. Better pieces than the new Volvo 42081 too. There are also two large turntables under the cabin. Btw. given the new claw piece and the fact that 2024 is Volvo year, I guess we can expect log loader L180H as 2024 flagship. Quote
allanp Posted May 2, 2023 Posted May 2, 2023 1 hour ago, 2GodBDGlory said: Except for the 8455 Backhoe, with its out-there 10 cylinders! That's why I said tied for second, it'll still be second but 8868 could go to third. Quote
Maaboo the Witch Posted May 2, 2023 Posted May 2, 2023 10 minutes ago, Repkovsky said: There are also two large turntables under the cabin. Btw. given the new claw piece and the fact that 2024 is Volvo year, I guess we can expect log loader L180H as 2024 flagship. Woah there, we're not even done with 2023 yet! Quote
Polarlicht Posted May 2, 2023 Posted May 2, 2023 Love it. Big old tractor to haul stuff They even could have used the yellow cylinders and it would not have looked stupid (unless real ones are grey as well) Butwhy those sport Edition rims again? Can not see them anymore! Quote
Maaboo the Witch Posted May 2, 2023 Posted May 2, 2023 7 minutes ago, Polarlicht said: They even could have used the yellow cylinders and it would not have looked stupid (unless real ones are grey as well) They are. Well, grey-black, anyway. Quote
2GodBDGlory Posted May 2, 2023 Posted May 2, 2023 32 minutes ago, allanp said: That's why I said tied for second, it'll still be second but 8868 could go to third. Ah, sorry, I see what you meant! Quote
allanp Posted May 2, 2023 Posted May 2, 2023 More pics available on Lego website Unfortunately they snuck in some LAs at the rear, and also the cam shaft style engine. Okay, so not everything can be perfect I guess, still very excited for this of course!!! Quote
Maaboo the Witch Posted May 2, 2023 Posted May 2, 2023 (edited) So the blade is operated by a gear on the side of the cab! Nice. I also like that TLG used the same image of the real thing that I posted a little while back! Edited May 2, 2023 by Maaboo35 Quote
Ngoc Nguyen Posted May 2, 2023 Author Posted May 2, 2023 This reminds me of when the CLAAS Xerion box design was revealed. Same feeling of awe. Quote
GoldVillage Posted May 2, 2023 Posted May 2, 2023 18 minutes ago, allanp said: Mini LA's for the blade works fine =) However whats missing is the rotating for the grabbler (just geared axle with a knob would had done it) but still, this seems to be the best set for years Quote
TechnicRCRacer Posted May 2, 2023 Posted May 2, 2023 9 hours ago, JonathanM said: Looks like 3x19 frames in green after all. What is the small black part in the pinhole of the green panel behind the rear wheel? Yeah, the other photo shows the 3x19 frame. The black looks like this part: https://rebrickable.com/parts/79194/plate-round-1-x-1-with-hollow-stud-and-bar-on-underside-long-space/#part_usage Quote
Saruzeufel Posted May 2, 2023 Posted May 2, 2023 25 minutes ago, GoldVillage said: However whats missing is the rotating for the grabbler Skidders usually do not have this feature IRL... so not having a rotation function is more realistic. Quote
Polarlicht Posted May 2, 2023 Posted May 2, 2023 2 hours ago, Maaboo35 said: They are. Well, grey-black, anyway. Then maybe thats the reason they have recolored them last year, for this set... Quote
zoo Posted May 2, 2023 Posted May 2, 2023 I'm probably missing something obvious here but what are the light grey parts holding the upper cylinder fittings to the A-profile boom? Doesn't look like a regular pin end? Quote
msk6003 Posted May 2, 2023 Posted May 2, 2023 Switch place looks strange but this is what called 'TECHNIC' model. Quote
mortenm Posted May 2, 2023 Posted May 2, 2023 Is it a sticker, or a lot of these that makes the grill? Quote
N-4K0 Posted May 2, 2023 Posted May 2, 2023 (edited) 5 minutes ago, zoo said: I'm probably missing something obvious here but what are the light grey parts holding the upper cylinder fittings to the A-profile boom? Doesn't look like a regular pin end? If you mean what I think you mean, it's this, released in 2021: https://www.bricklink.com/v2/catalog/catalogitem.page?P=77765#T=S&C=86&O={"color":86,"iconly":0} Edited May 2, 2023 by N-4K0 Quote
mahjqa Posted May 2, 2023 Posted May 2, 2023 1 hour ago, Michael217 said: [pictures] I can't make sense of the geometry of the A-frame. I would assume all holes on there are on a regular grid. Then how does the 11 stud flip-flop beam fit in? It appears to stretch between two holes that should, by all means, be more than 10 studs apart center-to-center. Quote
zoo Posted May 2, 2023 Posted May 2, 2023 5 minutes ago, N-4K0 said: If you mean what I think you mean, it's this, released in 2021: https://www.bricklink.com/v2/catalog/catalogitem.page?P=77765#T=S&C=86&O={"color":86,"iconly":0} Right. Thanks! Apparently, I don't buy enough sets. And/or don't build them fast enough. :) Quote
