Hello all,
I couldn’t find a thread on display cases or wall mounts so thought I’d ask here. I know @kbalage has reviewed some wall mounts for the supercars but they’re very expensive. Have other people used any other brands to display theirs ? I’ve seen a company called Unique Display here in the U.K. but not seen any reviews
Yeah I just have 2 white bookshelves, 28cm deep and 75cm wide shelves. I have models on around half the shelves and books on the others. The 1:8 cars fit perfectly and they were pretty cheap.
I doubt those cars were cheap... :tongue:
Haha smarty, well the cars definitely make the bookshelves seem cheap :tongue:  The latter of which were around $139au each which is pretty good considering it can hold 7 such cars on it.
4 hours ago, nerdsforprez said:
though they are a bit expensive.  There are really endless options if you just look up Lego wall mounts online
You can always go for a DIY option.
These are made by @vinkie_116 on Instagram using a wooden plank painted in the car’s respective color. Then they are hung by using these “panels” used for the Lego Art series.
3 hours ago, Seasider said:
I’ve been looking at these but wondered if anyone had any experience? As much experience as to what it means to the Technic set displaying them like this long term
https://uniquedisplay.co.uk/collections/wall-displays-for-lego-technic/products/wall-display-for-lego®-technic-42115-lamborghini-sian-pdw-02
I do not think it damages them if that is what you are referring to.  Not trying to overpromote or anything but I have a Lego room in which I have several Technic sets either hanging on walls (mount is something I made myself) or I use the idisplayit floor mounts which still place models at odd angles.
https://www.idisplayit.co.uk/
I take things off the mounts every now and then and inspect for any separated elements, damage, bending, etc.  I have not encountered any yet.  Things have been hanging for years.
20210710_201158i
see U-wing (Technic build) in upper right
20211121_091723
Even official Lego SW UCS sets come with stands, that, I get it are not the same as a vertical hanging, but still have a lot of stress when off surface, positioned horizontally.  I assume it is all okay.
i don't have alot of Technic but i do have displays for all my lego cars and MOCs. i got them from ikea and they are really good
I wanted to display the UCS millennium falcon on my wall, so I added some beams to the inner structure that hang out the bottom and make a wall hook (also out of Lego) and just hung it there, it's been there for 3 years, definitely the cheapest solution but it's a pain to dust! I am very tempted to make a plexiglass cover or something. It's pretty easy to cut and smooth the edges to a professional looking finish with a plane and scrapers (the edge of a metal rule makes a nice scraper btw).
