Aerolight Posted March 8, 2023 Posted March 8, 2023 Have finally improved my engine and the design now peaks at over 2800 rpm (almost 50 revolutions per second) and best of all it is a ridiculous mechanism, no simple slide valves and has 3 cylinders. For the video on it I want to make a sort of speed run history sort of video, where I go through the process of how I got to this engine. But I want to try to make sure that 2800 rpm is the highest currently obtained, has anyone seen an engine that revs higher, I have tried to keep a look out but mostly find videos vastly overclaiming rpm i.e. 8000rpm where the design is good for 1200rpm Excluding turbines, they can rev to over 10K rpm I know this is a fringe interest so sorry for asking such a specific question Quote
nerdsforprez Posted March 8, 2023 Posted March 8, 2023 Yes...fringe interest indeed. I would need more info why you discount others achievements. I searched for like five minutes and found several examples that appeared credible to me of over 10000 rpms. In all honesty, 2800 rpms isn't really that much for Lego vacuum engines. I am sure there are engines out there capable of much more. Quote
Aerolight Posted March 8, 2023 Author Posted March 8, 2023 (edited) can u link a video? they do sound like they run far faster than they do its a real disappointment when you measure it to me at least Sry did not mean to sound disparaging of other peoples mocs people have built ones far more impressive than mine just mine is optimised for rpm Edited March 8, 2023 by Aerolight Quote
nerdsforprez Posted March 8, 2023 Posted March 8, 2023 ? okay, but this is really just spit-balling. Literally just searched in YT. tons of hits right after. I did not look at specifics and a low degree of scrutiny, but after a cursory look, seems legit to me. Quote
Davidz90 Posted March 8, 2023 Posted March 8, 2023 I think he meant piston engine, not turbine. 2800 rpm is pretty impressive! Quote
Aerolight Posted March 8, 2023 Author Posted March 8, 2023 thanks they do sound a lot more impressive than then numbers suggest, super disappointed I could not get to 3k though even with a pre EU ban vacuum cleaner Quote
enginelegopower Posted March 21, 2024 Posted March 21, 2024 (edited) I made a LVE that uses the piston mechanism and tops out at 3,850 RPM. I measured the RPM in the same way that lucas dynamics used in his video. I agree that it is very impressive, we are catching up to vacuum turbines! Also mine is a one cylinder LVE Edited March 21, 2024 by enginelegopower Quote
LegoLord1880 Posted September 19, 2024 Posted September 19, 2024 If you are trying to get POWER out of a Lego vacuum engine, you'll want multiple cylinders(3 cylinders are EXCELLENT at this) If you're going for a speed record, a single-cylinder engine is the way to go. if you really want a faster engine with more than one cylinder, I suggest you make valve timing for each individual cylinder, so they don't "stumble" over each other when firing. Quote
