1000x800.jpg?1679591102.2990177
In the anticipation of the set 42157, I have created a smaller version of the John Deere 948L-II Skidder.
Functions:
- Liftable front blade
- Articulated steering
- Grapple arm
- Grapple articulation and rotation
- Openable doors
- Chair that can rotate 360 degrees
Other features include:
- Fire extinguiser
- Joysticks on chair armrests
- Winch drum behind the grapple arm
The biggest challenge during the design process is the lack of connectors and liftarms in green. This shortage has an even larger impact on the design, because a model at a small scale requires different types of connectors to achieve the intended shape. Even though some connectors technically do exist in green, they appear in very old Technic sets (1990-2000 ones). Therefore, a restriction I imposed on myself when designing this set is that I have to avoid as many as possible those old Technic connectors in green. In other words, I want to use the green parts that only appear in recent sets.
In the end I was not completely successful in reaching that goal, but I was close. Thanks to the recent John Deere Tractor and the Monster Truck that the liftarms in green return. This design only uses the green liftarms from these two sets. The green 3x11 panel has not been available recently, but it's not old. Its last appearance is in the 42078 Mack Truck in 2018. The only rare connector in green in this design is 3 of this:
They can all be swapped with black ones with little effect on the overall look.
Another part that I'm not quite satisfied with but don't really have any alternative is the slanting bars in front of the cabin. At that angle I can't use any existing connector like #3, and can only use universal joints. However, universal joints don't exist in black, so that part is not consistent with the pure black structure in the real model.
At first I planned to include double differentials and a working engine as well, but the placement of the mini LA in the rear prevents the former, and the linkage to control the front blade the latter. In the end the lack of those things don't really matter anyway. Overall I'm quite satisfied with how the design turns out.
Instruction: https://rebrickable.com/mocs/MOC-142846/nguyengiangoc/john-deere-948l-ii-skidder/
Edited by Ngoc Nguyen
Beautiful! :wub_drool:
Just have to love this scale, as you may included all the functions for the upcoming Lego set with 1/3 of the pieces :D
Did you build it in bricks and can show some pictures?
Where did you hide the actuator knob for the front blade? :-P
Front blade is controlled through a lever on the other side. There's no actuator because there's no space inside the front.
I only built the function modules separately with pieces of mixed colors to test the functions, and I already disassembled them.
No drive train and fake engine though.
Just now, SaperPL said:
You should have waited with the release of it.
I know right? I kinda regret publishing this too soon now. The reason is that I'm not sure if Jim is gonna organize a shrinking contest at all given his reservation, and I thought electronics would be allowed so I was confident on entering with the Airbus instead.
Photos are finally in! They are submitted by user seregiz on the Rebrickable page.
4 minutes ago, Jundis said:
Would have scored very high for the last TC :-P
Imma tag Jim to see how he'd grade this :grin:
@Jim If you have time, can you give this a quick scoring according to TC25 criteria :tongue: Just scores no explanation needed, just for fun
