KirTech LAB Posted May 29, 2023 Posted May 29, 2023 Hi everyone! I'd like to share my new motorization project. This time I've modified Bugatti 42151: BuWizz 2.0 receiver as a power source, BuWizz-motor for rear-wheel drive and PF servo-motor for steering. As usually I tried to keep the original look of the set as much as possible and it was unexpectedly difficult to place all the electronic components. The main problem is a width of the model - the inner space between doors is only seven stud wide, so it's impossible to place the receiver between the doors as it's eight stud long. So I've ended up with pretty unconventional receiver placement. You can find details and test-drive in my video: Thanks for watching :) Quote
Daniel-99 Posted May 29, 2023 Posted May 29, 2023 Nice project indeed! Is it possible to fit Buwizz 3.0 instead Buwizz 2.0? Quote
mla2 Posted May 29, 2023 Posted May 29, 2023 1 hour ago, Daniel-99 said: Nice project indeed! Is it possible to fit Buwizz 3.0 instead Buwizz 2.0? I did a version with a Buwizz 3. Do note if uses a PU large motor for steering instead of a PF servo. See https://rebrickable.com/mocs/MOC-133111/mla2/42151-bugatti-monster-bolide-extreme-rc/#details Quote
KirTech LAB Posted May 30, 2023 Author Posted May 30, 2023 21 hours ago, Daniel-99 said: Is it possible to fit Buwizz 3.0 instead Buwizz 2.0? Not In my composition. It seems the only way to insert 3.0 is to modify doors and to mount the receiver transverse. Quote
