TECHNIC SHRINKING CONTEST - ENTRY TOPIC
CONTEST INFORMATION
More information about the contest can be found in the general discussion topic.
WHAT DO I NEED TO ENTER?
Please take a careful look at the rules before posting in this topic. Each participant is obliged to create a post in this entry topic. Posts need to follow the rules stated below. Posts not following the rules will be disqualified so please read them carefully.
ENTRY POST
The entry post in this topic needs to contain:
  • Entry name
  • One or more images (max 4).  You can have combined pictures (4 in 1) as long as the picture isn't bigger than 1024x1024.
  • One picture of the original model
  • Embedded Youtube video (mandatory)
  • Link to the discussion topic
IMPORTANT
This topic should be used for entries only, so commenting is prohibited. Please use the general discussion topic for...well, general discussion on the contest, and individual discussion topics to comment on the individual entries.
  • Jim pinned this topic
42113 Bell Boeing V-22 Osprey
Functions:
- Fast spinning rotors:  geared up 8 teeth knob on the top.
- Swivel motors and rotors: geared down 12 teeth knob on the top with articulated quadrilateral for friction and stops.
- Folding landing gear: small linear actuator and 8 teeth knob at the rear.
- Two elements cargo door: small lever under the aircraft and linkage.
Stickers are from 42120 hovercraft (tailored, on the engines and tail) and from 42020 helicopter (blade tips)
embed?resid=5D1BF898A75E3C29!733&authkey
embed?resid=5D1BF898A75E3C29!729&authkey
embed?resid=5D1BF898A75E3C29!734&authkey
embed?resid=5D1BF898A75E3C29!730&authkey
embed?resid=5D1BF898A75E3C29!747&authkey
Discussion topic:
Edited by JoKo
new pictures
42043 Mercedes-Benz Arocs 3245
Original:
Functions:
  • Two-axle steering with different ratios and HOG control
  • Full live-axle suspension
  • Knob-operated outrigger extension
  • Basic outrigger leg deployment using pins
  • Dumping bed
  • Latch to allow the rear gate to open or remain closed
  • Knob-operated crane arm rotation
  • Pneumatic operation of the first crane arm joint
  • Pneumatic operation of the second crane arm joint
  • Pneumatic extension of the boom
  • Pneumatic bucket
Edited by 2GodBDGlory
42053 Volvo EW160E
Functions:
  • Hand of God steering front axle
  • Rear outriggers
  • Front blade with adjustable position and with lock mechanism
  • Front blade also can work as outrigger
  • 360 degrees superstructure rotation
  • Elevated cabin
  • Boom 1st section lift
  • Boom 2nd section lift
  • Working clamshell bucket
I made high quality instructions available at Rebrickable
Original model:
Simple graphic comparing shrunken and original set:
Video:
Edited by artemisovsky
42039 24 Hour Race Car
Features:
- steering system (removable HoG)
- full independent suspension
- engine cover opening
- openable doors
Side non set  feature - modular  building sequence
High quality instructions soon...
8284 Tractor
Functions:
- HoG steering
- Live front axle
- fake inline 4-cylinder engine
- Rear PTO (directly connected to rear Diff, NOT on-off controlled via the red handle)
- Adjustable rear hitch
- Foldable windrower
Free instructions at Rebrickable
Pics:
Original model:
Video:
Discussion topic:
Edited by falconluan
8110 Mercedes-Benz Unimog U400
Features:
  • HOG steering
  • openable side walls
  • pendular front suspension
  • winch attachment
  • crane attachment with outriggers
  • crane rotation, rise/lower
  • functional grabber
  • modularity - attachments may be attached alternately
Original model:
1000x800p.jpg?1658071740.9835982
Video:
Free instructions here: https://rebrickable.com/mocs/MOC-155114/TechnicMOCer/mini-8110-mercedes-unimog-u400/#details
Edited by TechnicMOCer
8109 Flatbed Truck
Functions:
- HoG steering with knob on the roof of the cab
- Flatbed platform raising with rear axles' kneeling mechanism
- Tow bar/tow platform hidden underneath rear bumper/lights bar
- Winch on the platform with a latch/lock mechanism
Original model:
Pics:
EVe96nch.jpg Full Size Photo Original Model
4NqbIaIh.jpg Full Size Photo Original Model
OctfjuEh.jpg Full Size Photo Original Model
GZyaB0hh.jpg Full Size Photo
Video:
Thread:
Free instructions: https://rebrickable.com/mocs/MOC-155661
8868 Air Tech Claw Rig
One of my childhood favourites, shrunken from 16 wide to 9 wide (56%). At this small scale, I was only able to keep two of of the four pneumatic functions and maintain the overall looks at the same time. Also the motorized pump is replaced by a manual one.
Functions
Manual functions:
  • HOG steering via the beacon light on the roof (same as in the original model)
  • V6 engine driven by rear axles (same as in the original model, except no differentials due to space constraints)
  • Pneumatic pump (motorized with 9V electrical motor in original model)
  • Crane rotation (pneumatically actuated in original model)
  • Gripper (pneumatically actuated in original model)
Pneumatic functions:
  • Crane lower arm
  • Crane upper arm
Original model
Pictures
Click here for high-resolution version
More photo's, renders and WIP on my Bricksafe. Instructions on Rebrickable.
Video
Discussion topic
Edited by lcvisser
8479 Barcode Truck
Functions;
  • Electronic Code Pilot system replaced by Gear Pilot system: coding by gear racks on the road!
  • Tire lift arm up by gear rack on the road and strings through hoses to replace the cable flex system.
  • Tire lift arm open and down by gear rack on the road
  • Tipper up and down by gear rack on the road
  • HOG steering with small turn radius
  • Moving steering wheel
  • Removable dummy Code Pilot box.
Original decals used:
40% smaller, 60% of original size:
Compared to original vis Stud.io render:
Free building instructions on Rebrickable:
https://rebrickable.com/mocs/MOC-156049/Berthil/8479-barcode-truck-shrink/
Discussion Topic:
42082 Rough terrain crane
55% of original size
Functions:
Single control of all functions with one rotary knob through 2 gearboxes:
- outrigger control
- rotation of the upper platform
- lifting/lowering the boom
- changing the length of the boom
- winch
Also:
- four-wheel drive with a fake engine
- 4 wheels steered
- detailed operator's cabin with opening door
Original set:
Photos:
Edited by Akassin
42069 Extreme Adventure
One of my favourite sets, designed by @grohl back in 2017 in 2/3 scale.
The model was originally deisgned in LDD and than replicated with real bricks.
It measures 29x16x18 cm and is built out of exactly 1444 pieces.
(Replicated) Functions:
  • Articulated and functional tracks
  • All wheel drive
  • Working fake V8 engine driven by the tracks
  • Live axle suspension on both axles using soft shock absorbers
  • HOG steering
  • Bistable opening doors using small shock absorbers
  • Opening side panels with fire extinguishers
  • Lockable rear door with a friction based locking mechanism
  • Rear compartment can slide out, revealing a showel
  • Liftable roof with an openable tent actuated by the small linear actuator
  • A working winch with friction to keep it in place
Video of the model:
Photo of the original reference:
42069.jpg?fit=bounds&format=jpg&quality=
Photos of the finished downscaled replica:
Discussion topic:
Edited by Zerobricks
8446 Crane Truck
In 1:1.5 scale or around 66% of its original size. With all functions of an original set.
Functions:
  • Double front axle steering via HoG (with first axle steer angle being slighty larger than 2nd)
  • Cabin opening by pushing spring-loaded mechanism at the front
  • Crane superstructure rotation (360 degrees) via side knob
  • Crane arm control via side knob
  • Spring-locked grapple controlled via knob
Original model:
Pictures (all pictures are clickable for higher resolution - once clicked -> right click -> open picture in a new tab):
Video:
Thread:
Edited by Equilibrium
Name: Mini Extreme Cruiser
Features:
  • independent front suspension
  • rear swing axle with shock absorber
  • HOG steering
  • Working drivetrain with differential and fake V4 engine
  • Opening doors, hood, and trunk
  • Detailed front and rear facias
Original model:
Mini Extreme Cruiser:
Video:
Discussion topic:
Edited by lmdesigner42
Truck 8436
Shrinking of about 79% of it's original size.
Functions:
All according to the original model including the 3 pneumatic attachments: Crane, grapple and towing unit.
- Steering with HOG
- fake V6 engine
- tilting cabine
- Quick change with only 4 pins for each unit
- Pneumatic actuation of the 3 units:
  • Crane: Main and secondary boom, rotation via worm gear, third wheel attachment
  • Grapple: Main boom and claw, rotation via worm gear
  • Towing unit: Elevation and towing platform
Pics with original (copyright @www.brickowl.de):
shrunk to 60%
Gearbox and functions operate like the original powered through a HOG power knob/crank.
- forwards and backwards drive
- Infinite slewing
- boom and grabber raise and lower
- boom extension piece
- Easy to use grabbing claw
- cabin tilt
Original model:
Video (sorry it’s so long at 7mins but I’m slow and there was a lot to show with so many functions and features)
Photos:
Edited by MangaNOID
trying to embed video
41999 4x4 Crawler shrunken to 70%
- 4x4 drive train
- front and real live axles
- 4 wheel steering operated with HoG, rear wheels are steered in 1:2 ratio
- secured manual winch operated with HoG
- mini V8 fake engine
- openable hood and trunk
Picture of original set:
Pictures of my model:
Video:
41999 4x4 Crawler Exclusive Edition
A great looking off-roader that I never owned as the original set. Shrunken to about 70% of the original. Aimed at keeping the chassis structure, suspension geometry and the paneling similar.
Features - all that the original has
  • 4 wheel drive, with a mini V6 fake engine under the hood
  • 4 wheel steering, linkage based, identical steering radius on both axles, HoG on the roof
  • live axle suspension with portal hubs and differentials, elevated entry point of drivetrain
  • working front winch with ratchet mechanism and release lever
  • openable doors, hood and trunk
  • interior with seats and dashboard
Picture of the original
Lego_Technic_41999_4x4_Crawler_(95310670
Pictures of the shrunken version
Video
Link to discussion topic
Edited by gyenesvi
42054 CLAAS XERION Trac VC
Shrink factor: 1/2 (from Tire 107 x 44R to Tire 56 x 26)
Functions:
- Openable hood
- Rotatable cabin
- 3 steering mode: 4 wheel steering, crab steering, front wheel steering
- Movable front counter weight
- Movable crane hitch
- Crane rotation
- Outriggers
- Crane arm lift
- Crane arm extension
- Grabber rotation
- Movable grabber claw
Photos:
Video:
Discussion thread:
Edited by Ngoc Nguyen
8868 Airtech Claw Rig
Shrink factor: 70%
Includes all features of the original replicated as faithfully as possible, except motorized compressor (replaced by manual pump as per rules of the contest). I was unable to finish the build properly due to missing parts which I had ordered, so few details are missing, like the horns on the top of the roof and few are coloured wrongly, such as some parts in front mudguards.
The features include:
- Rack and pinion steering with HOG control
- Two rear axles with differentials driving front V6 fake engine
- Five pneumatic cylinders, two of which are used for slewing, one for boom, one for jib and one for claw
- Aesthetic touches of the original replicated as far as possible given the scale and functions
More photos in the wip topic:
Edited by howitzer
Well, hope I am not too late,:innocent2:
"Honey, I shrunk the 8454"
Finished model:
working steering, opening doors, working joystick-operated arm, trans neon headlights
Original model (image borrowed fromRebrickable, as my copy is disassebmeled for long time)
1000x800p.jpg?1686123411.4836946
  • Jim locked this topic
  • Jim unpinned this topic
