Marius2002 Posted July 28, 2023 Posted July 28, 2023 (edited) Hello I'm new to Eurobricks, and I really wanted to share this Millennium Falcon that I made, and get some thoughts and opinions on the design. It is currently only a digital model, but I'm planning to get the pieces and build it at some point in the future. Thank you for your time! Here is a link to the instruction and partlist if you're interested in building it for yourself. https://rebrickable.com/mocs/MOC-154536/Marius2002/millennium-falcon/#details Edited July 28, 2023 by Marius2002 Quote
Guyinaplaguemask Posted July 28, 2023 Posted July 28, 2023 Very nice looking, but the mandible look like they should be a bit thicker. I don't know how you could do this, but it is a thought. Quote
Per_SW Posted July 29, 2023 Posted July 29, 2023 That's a wonderful looking model, love the choice of an unusual scale. I do agree with the above comment and now think that the mandibles could be a plate thicker, but didn't notice the "issue" (very heavy quotemarks, but I'm not finding a less heavy word than "issue") before reading that, so it's not even that evident to me :D Keep up the good work, and kudos for giving the Solo version some love. Quote
JACKATTACKS Posted July 29, 2023 Posted July 29, 2023 Woah this looks fantastic! Love the use of the barrels on either side and the tessellation of all the angled parts. My little nitpick would be is it possible to make the two round black tiles at the back face up the same way as the other four for a more coherent look? Anyways, phenomenal moc of falcon! Quote
Marius2002 Posted July 29, 2023 Author Posted July 29, 2023 Thank you so much for your kind words and great feedback. I made some changes to the models based on the comments you made. The biggest change was that I remade the mandibles to be a tiny bit thicker. I used bricks and slopes instead of plates and wedges, which also gave it a smoother, studless look. I also redid one of the panels on the back to make all the black round tiles face the same way. some minor changes was also done to make it a bit more accurate. Quote
Chrome Vader Posted July 29, 2023 Posted July 29, 2023 You have captured the proportions and details really well in this small scale! I like most of the modifications you made in these most recent photos, although I would say that I miss the stacked roller skates on the tips of the mandibles--that was a fantastic design idea. I like that the blue engine strip is more visible now. Is this model mountable on a stand for display? Quote
Marius2002 Posted July 29, 2023 Author Posted July 29, 2023 I tweak the mandibles a bit more and managed to get the stacked roller skates back. The only issue is that the two slopes used are at two different angles. It's really subtle but noticeable. Yes the model has mounting points for a stand. I have already designed a simple stand for it, but any stand would work. It attaches to the bottom with two pins Quote
Sylyphics Posted July 30, 2023 Posted July 30, 2023 I actually preferred the first mandible iteration, as the second version lost the texture of the plate built, and now integrates less well with the busier texture-wise main hull. Perhaps consider using bricks with studs on sides and brackets to add detailing back in? That said, brick-built would likely still miss the sidewall greebling that the wedge plates gave the outer edges of the mandibles, which was a nice continuation of the sidewalls from the main hull. Quote
Marius2002 Posted July 31, 2023 Author Posted July 31, 2023 On 7/30/2023 at 8:28 PM, Sylyphics said: I actually preferred the first mandible iteration, as the second version lost the texture of the plate built, and now integrates less well with the busier texture-wise main hull. Perhaps consider using bricks with studs on sides and brackets to add detailing back in? That said, brick-built would likely still miss the sidewall greebling that the wedge plates gave the outer edges of the mandibles, which was a nice continuation of the sidewalls from the main hull. Yes, I agree. The second iteration is very smooth and clean in comparison to the rest of the ship, so I went back to the plate design and built on it. I managed to keep the thickness of the brick built version and also add detail. I cant decide weather I like it or not. It's a lot more detailed than previous iterations, but it might be too detailed. Quote
Sylyphics Posted July 31, 2023 Posted July 31, 2023 8 minutes ago, Marius2002 said: Yes, I agree. The second iteration is very smooth and clean in comparison to the rest of the ship, so I went back to the plate design and built on it. I managed to keep the thickness of the brick built version and also add detail. I cant decide weather I like it or not. It's a lot more detailed than previous iterations, but it might be too detailed. Better detailed now than smooth IMO, though it changes the look. Part of the effect that it looks more detailed is that it now has a lot more of a negative-space type look, as if what we are seeing is the inner part of the mandible with the top section removed, the epidermal layer of hull if you will. Looking at some photos of the film prop it seems the mandibles are almost the same thickness as the edge of the hull "dish", so you can likely get away with bulking them up a bit more visually. Quote
LordsofMedieval Posted August 2, 2023 Posted August 2, 2023 I don't generally like midi-scale, but the execution here is just supremely good. Quote
Marius2002 Posted August 3, 2023 Author Posted August 3, 2023 23 hours ago, LordsofMedieval said: I don't generally like midi-scale, but the execution here is just supremely good. Thank you so much! Quote
Powder Monkey Posted August 11, 2023 Posted August 11, 2023 I have to admit the older I get the more interesting I find the midi-scale. Maybe because it's so difficult to keep things in proportion and make it look good at the same time. But you nailed it sir! Quote
Marius2002 Posted August 12, 2023 Author Posted August 12, 2023 On 8/11/2023 at 9:17 PM, Powder Monkey said: I have to admit the older I get the more interesting I find the midi-scale. Maybe because it's so difficult to keep things in proportion and make it look good at the same time. But you nailed it sir! Thank you! Quote
