LordsofMedieval Posted October 14, 2023 Posted October 14, 2023 Okay, this time there is no prototype - just lifting some SNCF practices (valve chamber location; triangular cab; firebox design; 'flapper' stack cap) and producing an Orient Express locomotive that could slot in with the provided tender and won't break the bank (565 pieces total). It's powered by a single medium PU motor, but that's the same thing I expect to see in the OE set, so I don't think there will be any issue (I anticipate that the battery pack will be in the tender). Other highlights: There are no custom pieces. Everything is stock. The valve gear isn't designed to 'work' - just simulate function via motion and gravity. If the color is wrong, it could easily be changed in stud.io (there seems to be a debate on which blue the set will be released in). HERE IS THE DOWNLOAD LINK. Quote
XG BC Posted October 14, 2023 Posted October 14, 2023 looks good. takes the sloped front of the original design into account while still being easy to build. i like it. Quote
Shiva Posted October 15, 2023 Posted October 15, 2023 I, actually prefer the Orient Express, locomotive. Quote
