iknnn Posted November 18, 2023 Posted November 18, 2023 the app for the Lego tetehnic is saying that 2 cables aren't connected where they should be but they are connected right Quote
Alex Ilea Posted November 18, 2023 Posted November 18, 2023 Hi, make sure you reconnect the motors, see if the app is updated in the playstore, relaunch the app, maybe restart phone. Hope it helps! Quote
Zerobricks Posted November 18, 2023 Posted November 18, 2023 I recommend you guve us more info, which set, what motors, etc... Also double check instructions, or reinstall the app if all else fails. Quote
Zerobricks Posted November 18, 2023 Posted November 18, 2023 Again, the more information we get, the better we can help... Quote
Zerobricks Posted November 18, 2023 Posted November 18, 2023 Have you tried reinstalling the app? Quote
Maaboo the Witch Posted November 18, 2023 Posted November 18, 2023 Probably seems a bit obvious, but are you entirely certain that the correct cables are in the correct ports? Quote
iknnn Posted November 18, 2023 Author Posted November 18, 2023 yes i am i even tried switching the both Quote
MikeTwo9398 Posted November 18, 2023 Posted November 18, 2023 (edited) I had a different issue this week. Try this maybe it helps (reminder: it removes all collected data of the other vehicles in the app):Posted Thursday at 06:02 PM On 11/12/2023 at 12:39 AM, MikeTwo9398 said: Just a question if someone else has the same issue as I do at this moment. When I want to control 42140 with the control+ app on my Android telephone, a Samsung A52, it keeps hanging when the green bar is full. Other vehicles work ok. I tried re-installing the app, restarted my phone, same problem. on my daughters I-phone all works ok. Am I the only one with this moment? Contacted Lego Service, Issue solved Advice was to delete the Storage and Cache and reinstall the Control+ app on my phone: device settings - apps - control+ - storage and cache After doing so for some reason the Storage was not removed. I delete the Storage and Cache again but did not reinstall the App and then the issue was solved. Edited November 18, 2023 by MikeTwo9398 Added reminder Quote
iknnn Posted November 18, 2023 Author Posted November 18, 2023 that didn't work i tried using an diff phone but the issue was the same i already contacted Lego service Quote
Zerobricks Posted November 18, 2023 Posted November 18, 2023 Good luck. I can tell you from my personal experinces that the Slovenian LEGO costumer service is great! Quote
iknnn Posted November 18, 2023 Author Posted November 18, 2023 my problem was fixed and thanks to everyone for trying to fix my problem Quote
