There's much excitement about the forthcoming Orient Express set (only a few days now!) so I thought I would jump on the bandwagon and design a 6-wide dining car.  It's 30 studs long with a City theme vibe.  This is the inspiration prototype:
640px-Wagons-Lits_dining_car_in_Austria_
(from Wikipedia)
I designed it in Lego Digital Designer.  I was keen to capture the black structural girder supporting the sides, recessed doors and striping.  I wanted to keep to readily available bricks so used yellow rather than gold striping.  Because of the internal construction the lower part of the car is only 4 wide but I have tried to create some interior.  Anyway pictures tell a thousand words...
I had about half the necessary parts and have ordered the rest on Lego pick-a-brick and a few on Bricklink, so I hope to be able to build it in a few weeks.
looks nice. one thing you could improve is the rear parts, make the roof 6 wide but keep the section under it 5 wide or make that slightly wider. like 5 wide and one plate or something.
Thanks. I'll take a look when I get the bricks to build it IRL.
4 hours ago, LEGO Train 12 Volts said:
Nice wagon, I lile the livery! :wub:
Thanks. I can't take credit for the livery though! :-)
Just to prove I do occasionally build something rather than just design things, here is the completed CWIL buffet car.
I had to change the design of the steps as they proved to be "unbuildable" using these parts (#4865 Panel 1 x 2 x 1) ...
so instead I just used a 2 x 2 tile on the top of the bogies which works fine.  I think it turned out quite well.
