Miszuq Posted December 25, 2023 Posted December 25, 2023 so a while ago i made this custom cyborg from the mandalorian for the spider tank (also i based it on a reddit post but slightly modified it) but now when i have the spider tank turns out.. it doesn't fit can you guys suggest how can i modify it so it would fit in the spider tank? Quote
Murdoch17 Posted December 25, 2023 Posted December 25, 2023 (edited) In the show, I think his head detached itself from it's bipedal body and rode on little legs into the spider tank. So only the eyeball, the bracket, the slope, and clip need to fit in the spider tank - not the whole figure. I hope this helps you @Miszuq! Edited December 25, 2023 by Murdoch17 Quote
Miszuq Posted December 25, 2023 Author Posted December 25, 2023 thanks but i also want to fit the rest of the body inside because i don't know where to put it decapitated Quote
Mandalorianknight Posted December 26, 2023 Posted December 26, 2023 Was the version (before you modified it) supposed to fit inside the spider-tank? I don't own the set, but looking at it, I don't think this guy can fit without some major design changes (I'm assuming you want the cannon lowered enough that you can't see this guy under it?) His hips are pretty wide for the 2-wide part of the space, as are the arms, and the spines prevent you from sort of shoving him in vertically. (Not to mention, this entire build is pretty delicate. This thing's gonna come apart every time you try to fit it inside/take it out) If I were you, I'd just go with the canon version. If you're worried about display- people can't see the head inside, so you could just have the entire build off to the side. Maybe make a cage for mando by it! Quote
Miszuq Posted December 26, 2023 Author Posted December 26, 2023 (edited) 8 hours ago, Mandalorianknight said: Was the version (before you modified it) supposed to fit inside the spider-tank? well, it was supposed to fit in the spider tank, but it was posted like 5 months before the set even released Edited December 26, 2023 by Miszuq Quote
