7 hours ago, Aurorasaurus said:
Its very simple but recognizable, very elegant. Are you able to share more detailed photos of the drivetrain, possibly without wheels?
Thanks and of course I will take some pics for you today.
7 hours ago, 2GodBDGlory said:
Looks nice! In some ways that style is like a mid-2010s style, which is nostalgic for me now...
Thank you, it is the style I try to do, strong and recognocible with the less parts possible.
The pics I promised. As usual the part I am more very proud is the steering and you can see it is a non asimetric tatra, I can not with that awful tatra charasteristic. I will do some changes in the chassis for the instructions but just some small ones. I do not like the Lego control but it will be easy to change it for the power functions.
Edited by jorgeopesi
Jorge,if I understand correctly, left side is driven by 12 to 12 black double bevel gears and right by 20 tan bevel gears?
Kind regards
Kind regards
I does not matter you can use them as you wish because you can change them in the drive central axle.
I understand that...I wanted to make independant drive to left and right half-axle, but so far could only manage something like that
Which is the vehicle and what do you want for the axles, suspension, differential steering etc?. In that scale should be possible to achieve something good.
Happy new year and also new total chassis redesign but finished...
It was not as strong as I wanted so I come back to the rubber liftarm solution, now it is stronger ald lower.
This is the rubber suspension on every axle.
The chassis now is enough stronger.
The motors and battery are easily removable and you can change the gears easily to get more power, speed or whatever.
Now I want to do the back part and another cabin types to can have different trucks, classic or trial trucks for example.
On 1/1/2025 at 8:44 PM, NV Lego technic said:
Wow! I love the framework design!
Thanks, I had not seen it.
I worked a little and I almost finished the instructions.
It is finished, I tried to do back part but I failed... I will open a thread a will try to do a short explanation and video. A 8x8 tatra with 2 steered axles each one with different angle steering and full suspension no more no less with 0nly 705 parts so far. The part I like the most is that you can easly change the gears due the modular construction looking for speed or climbing.
6 hours ago, NV Lego technic said:
Is there enough space to put the hub on the front? Very cool model, and also the modular construction is great.
Thanks twice, your suggestion is correct but it would be too much weight on the front part, but anyway it was useful because I put the steering motor on the front and I was able to put the battery lower than before. That is why I like to share all my progress, you can have good advice at any time, a first slook from someone outside the project may be better than mine. Now I will give another chance to the back part...
