Wardancer Posted February 15, 2024 Posted February 15, 2024 Marwood Outfoxer Marwood Outfoxer (revisited 2024) by MWardancer Customization Notes: - hood: painted - scarf/mask: painted, I had to cut off some parts in the back in order to make space for the quiver - quiver: does not use a neck brace anymore, but a pin which I glued to it. the pin goes through a hole in the cape into a hollow stud which is glued to the back of the fig. I don't like archers without arrows. - cape: I have a special hole punch to make the hole for the quiver - bow: painted a little I have a regiment pending, in which I will vary some colours a bit. It might take a while as the paint job here is quite long. Two layers of green and one layer of semi-glossy adds up to quite some work. Some of the parts were quite expensive. But I am very glad this worked out, I like how the hood with the ears matches the wolf/fox brooch. Quote
Yperio_Bricks Posted February 15, 2024 Posted February 15, 2024 The painted hood and scarf look fantatstic! Great minifig all around! Do you have a picture that shows the figure from the back? Quote
Wardancer Posted February 23, 2024 Author Posted February 23, 2024 On 2/15/2024 at 10:18 PM, Yperio_Bricks said: The painted hood and scarf look fantatstic! Great minifig all around! Do you have a picture that shows the figure from the back? Thank you. Here it is: Backside Techniques by MWardancer, auf Flickr Quote
