One would think that at least at nearly 1:1 scale LEGO would get rid of the ugly blue pins and yellow axles, but they have to stick to their brand values lol.
  • Replies 609
On 7/12/2024 at 7:01 PM, rm8 said:
Or my Land Cruiser...
  • 12 years ago
  • the same suspension config,
  • rear and middle difflock
  • manual 5+R Gearbox.
  • the same width of body - 23 stud as G500
My first MOC afte dark times. Still alive and work well on my shelf. Survived Defender, and will survive G500 for sure.
Doc, send me all that new panels back to the past:)
This moc should be updated and re-skinned to a new LC 250 or Lexus GX
Edited by Milan
Removed quoted text and images.
Finally, the G Class set released! Thanks TLG for providing a baseline and new parts!
Really look forward the modification of this set (or "wish list" LOL):
  • Quick removable body, it is always good to see the chassis detail and easy to maintain.
  • RC version(Performance-driven and Ready-to-run on the terrain)!
    • RC Steering (maybe with steering wheel linkage)
    • RC RND/High/Low gear selection
    • RC Central / Rear diff lock(maybe linked with Low gear?)
    • Bonus:
      • RC Front diff lock...maybe it is too hard to fit into this small scale IFS...
      • RC winch as optional part
If you would like to share your "wish list" that would be great too! Cheers!
Or if you really want to push yourself, maybe a 7+N would do, but I can't see how could it be implemented with RC without sacrificing the interior. Or, a DNR selector would make sense if you used an LPE to power the model, but then, fitting a 3x diff lock, valve motors, and an air tank would be challenging
At first I was not interested in the G500, it seemed to be just another technic car, another Land Rover...
But the more I see the better it looks.
I like the drivetrain without excessive gearboxes (that only causes issues).
Damn, I should not buy another set this year... :devil_laugh:
1 hour ago, thekoRngear said:
A bit detailed demo of function of the car.
- the lever mechanism on top of gearbox levers is for 2wd/awd
Are you sure he's right about that? I thought it was confirmed that the three levers were DNR, Hi/Lo, and central diff lock?
Cannot tell for sure. Take a look at it. He switches the lever with satisfying click and, both pair of axles move. Before switching it was only the rear axle. In both cases the other guy was moving the red gear of the rear diff.
Of course you guys are more expert on this one. :classic:
Btw do you think it will have rolling resistance as much as the Ford Raptor/42126 had?
Edited by thekoRngear
I'm probably not going to take the time to find the spot in the video (Sorry!), but that behaviour does sound consistent with a central differential lock. With it unlocked, the tendency would probably be for the rear axle to just run the engine extra fast, while with it locked, the front wheels would have to go along with it
That's because front axle has more friction than the rear one, so when the central diff is unlocked, the drivetrain chooses to only propell the rear axle. But when the diff is locked, it's forced to drive all wheels so it looks like an rwd/awd selector.
Quote
Honestly makes more sense. Thanks guys!
I will edit the post now.
Yep! Though I think he was saying it's being shown working in reverse in the video, being manually driven from the rear axle instead of from the engine
So the rear diff lock is not  connected to the third cabin lever right?
Edited by SNIPE
I just watched a speed build of it, nope, the rear diff lock seems to be manual only... :/
Maybe it's a good thing they didn't make the rear axle differential lock automatic.
Since this is a manual model, there is a good chance that the gears of the differential in the rear axle will break during driving, especially given the profile of the new tires.
I seriosuly doubt that, those diffs are very strong and the load is spread over multiple gears.
