Skalldyr Posted April 3, 2024 Posted April 3, 2024 Hey there Eventees! with it beeing one Month until we will see each other again in Günzburg it is time for an event building challenge! This year it will be: Build your own "Little Corner Space". So get creative and show us what you can come up with. It can represent a space fitting for you or be a space for your sig-fig (just tell a good story about why this is the build you choose).That way we also learn even more about each other. The rules should be easy (if you have questions just ask) and as following: Use LEGO to build a vignette on a 8x8 plate.Keep it in the following dimensions: 8x8 plate with two walls being 6 bricks high. Top it off with a row of tiles with some studs exposed.That way we can stack them together at the event and build a nice struckture. Therefore it should not have an overhang that would block this option. The space inside the walls should be filled with your imagination and your sig-fig or person inhabiting the space.And most importantly - Have fun! Here you find a reference picture: All the best and see you soon in Günzburg Quote
