cozzie4d Posted April 21, 2024 Posted April 21, 2024 Hi all, I've noticed that my track cross (7857) bends down when a train drives over it. Unfortunately there are no 'stud connectors' at the bottom to make it stronger/funded. Any best practices on fixing this? Quote
Andy Glascott Posted April 21, 2024 Posted April 21, 2024 (edited) I’m pretty sure a 1 wide plate will stick to the underside of the track along the length of the track, maybe try that? I can’t remember what the underside looks like but do remember the metal connectors are underneath so it might not be possible to run a couple of 1x8 plates the length of it… I’ll have a look at mine later and see if there’s anything else I can think of. Update Yes, I was able to put a 1x12 plate under the crossing, across the gap where the metal connections are, attached to the underside of the rail. Edited April 22, 2024 by Andy Glascott Update Quote
cozzie4d Posted April 22, 2024 Author Posted April 22, 2024 Thanks, I didn’t know 1x12 existed :) if you have a picture that would be great Quote
Andy Glascott Posted April 22, 2024 Posted April 22, 2024 Here you go - https://flic.kr/p/2pLJC3U Quote
cozzie4d Posted April 22, 2024 Author Posted April 22, 2024 Ah that's a perfect solution, thanks. I'll get some 1x12's, ideally in light or dark grey. Thanks again Quote
