Stereo Posted May 22, 2024 Posted May 22, 2024 (edited) 2 hours ago, Divitis said: Interesting, do you maybe have an example at hand? 42604-1 has one in the escalator, I don't remember the details. 8299-1 has a nearly-correct diagonal forming its tail that has axles compensating for a "2 stud" distance that's actually 1.97 if everything were exact. Unless it's a 3-4-5 triangle I think you'll find a lot of diagonals are near fits. They can be hard to spot since they don't stress any parts. I don't know if the axle or pin has more tolerance; you can probably gauge it to some degree by seeing how much they freely tilt when inserted through a liftarm. The 7L thin liftarm just drops into place like this, with no stress on it, actually it could go to a steeper angle no problem if they're both tan. Hopefully clear what parts I'm using (tan frictionless, blue friction pin+axle) Edited May 22, 2024 by Stereo Quote
Divitis Posted May 23, 2024 Posted May 23, 2024 11 hours ago, Stereo said: The 7L thin liftarm just drops into place like this, with no stress on it, actually it could go to a steeper angle no problem if they're both tan. Hopefully clear what parts I'm using (tan frictionless, blue friction pin+axle) Thanks, I replicated it to see how it 'felt'. I'm definitely OK with using this kind of tolerance when securing a panel which on the other hand is connected through a ball joint, for example. Still wouldn't use it as a structural solution (i.e. building a wall on top of it) though. Quote
