TECHNIC 49.5 x 20 TIRE VEHICLE CONTEST - ENTRY TOPIC
CONTEST INFORMATION
More information about the contest can be found in the general discussion topic.
WHAT DO I NEED TO ENTER?
Please take a careful look at the rules before posting in this topic. Each participant is obliged to create a post in this entry topic. Posts need to follow the rules stated below. Posts not following the rules will be disqualified so please read them carefully.
ENTRY POST
The entry post in this topic needs to contain:
  • Entry name
  • Short summary of the functions.
  • One or more images (max 4).  You can have combined pictures (4 in 1) as long as the picture isn't bigger than 1024x1024.
  • Embedded Youtube video (not mandatory)
  • Link to the discussion topic
IMPORTANT
This topic should be used for entries only, so commenting is prohibited. Please use the general discussion topic for...well, general discussion on the contest, and individual discussion topics to comment on the individual entries.
  • Jim locked this topic
  • Jim pinned this topic
  • Jim unlocked this topic
Dune Basher Retro
Functons:
  • Front ndependent suspension, rear trailing arm suspension.
  • I4 micro-styled engine with differential driven by rear wheels.
  • HOG steering with working steering wheel.
  • Opening trunk and hood.
  • Bold retro see-thru design with simple but accurate detailing and color coding.
Photos:
Link to topic
Truck-Mounted Forklift
Functions:
  • HOG Rear-wheel steering
  • Knob-operated front wheel 90 degree turning (Sideways drive mode)
  • Knob-operated mast sliding (Forward and backward)
  • Knob-operated mast lift
  • Knob-operated mast tilt
  • Knob-operated scissor-fork-extend mechanism
  • Manual fork side-to-side sliding
90’s Kei Truck
Functions:
HoG steering with moving wheel in the Cabin
Opening Doors
Switchable 4WD - switch in Cabin to select RWD or 4WD just like the real vehicles
Fake 3 cylinder engine
Front and Rear Differentials
Tipping rear bed - controls on both side of the vehicle under bed
Folding sides to the bed
53945192937_866649160f_b.jpg53946093466_8c2fc31b49_b.jpg53946429569_ce51a3d7c1_b.jpg53946093641_a982bbe665_b.jpg
Edited by Seasider
Concrete pump truck GBC
Function
Drive using spike medium / RI angular motor
Steering using C+ L motor
GBC using PF L motor
Openable door
Openable both side component door
Extending outrigger and arm
KakaoTalk_20240825_215048509_03.jpgKakaoTalk_20240825_215048509_02.jpgKakaoTalk_20240825_215048509.jpgKakaoTalk_20240825_215048509_01.jpg
Edited by msk6003
Airport Stair Truck
- Boom raise
- Opening tailgate
- Platform extension
- Platform levering
- Scissors stairs (always 90°)
- Working outriggers
- 4l-engine
- Working steering wheel + HOG
- Opening doors
- Opening engine bay
Fire department all road / off road truck
- 6-wheel drive
- 2 front-wheel steering
- Suspension on each axle via floating axles and panhardt bar
- Opening hood and doors
- Steering via HOH, rack-and-pinion transmission
- Pneumatic function for unloading arm lifting
- Pneumatic function for lifting mode selection. Choice between hooklift and dumper
- Pneumatic locking function for container-gripping hook
- Container with wheels and opening doors
vid:
Link to the Topic
- 6-wheel drive
vid:
Link to the Topic
That is really impressive, a lot of functions and good looks, too!
Please don’t post replies in the entry topic.
Vintage baja buggy
Features:
  • steering through 1x PF servo; it can be replaced with a Geekservo;
  • 1x PF L motor geared up to 1.67 for the rear-wheel drive; it can reach around 8-9 km/h / 5-6 mph with 1x MK 4.0 hub and 1x MK black L motor;
  • a front assembly with positive caster angle;
  • a suspension with a fairly long travel trough 4x hard 6.5L shocks with independent type in front and solid-axle type at rear; for a more realistic suspension behavior, soft shocks should also work;
  • a detachable bodywork.
Edited by Lixander
Purple hook-lift truck
The functions are operated manually:
  • There are four black gears on the top of the cabin:
  1. 20 tooth gear, steering of front axle + rear axle (if not lifted; if the rear axle is liftes it is locked in middle posistion) + steering wheel)
  2. 12 tooth gear, left: liftable rear axle
  3. 12 tooth gear, right: extractable rear bumper
  4.  12 tooth gear, middle: long Linear Actuator for hook-lift function and dumping
  • The red lever on the left side is for mode switching (hook-lift or dumping).
  • The black 12 tooth gear at the front of the container controls the opening tailgate.
Driving functions:
  • The three beacons (two on top of the cabin and at one the rear) rotate while driving (generally, this is my favourite function which I do ever since I built MOCs within the last 35 years. Almost every MOC of mine has rotating warning lights  :-)
  • The fake engine (V 6) works while driving.
  • Front PTO (right above the licence plate)
Link to the discussion topic:
[TC 27] Purple hook-lift truck - LEGO Technic, Mindstorms, Model Team and Scale Modeling - Eurobricks Forums
Edited by Timewhatistime
Heavy Duty Forklift
Features:
- raise and lower forks by 20 studs with knob
- tilt mast with knob
- steering with knob as well as steering wheel, with Ackermann correction
- 3 cylinder fake engine driving front wheels, located behind the cab
- opening engine hatch and rear compartment
- forks manually slide sideways to suit varying loads
Multi Purpose Vehicle - Futuristic Vision
Features
  • Steering
  • Suspension
  • Extending chassis for loading 'stuff'
  • 2 cylinder engine
  • 4 wheel drive
  • Adjustable steering wheel
  • Rear crane
  • Storage bins
  • manual tipping tray
Topic Link:
Edited by MangaNOID
Aussie Overlander Pickup Truck with Hybrid Camper Trailer
Features of the Pickup Truck:
  • Torsion bar suspension
  • 4WD/AWD with (full-time locked differentials)
  • Full RC, 1x L motor for drive and 1x M motor for steering
  • Custom Tradie tray (Removable canopy + flatbed)
  • Trundle drawer for Tradie tray
  • 2 Large compartments in the Canopy
  • 2 Small compartments for the flatbed
  • A foldable tabletop is stored in the canopy.
  • Many cosmetic features and interchangeable items to improve and change the look!
Features of the Camper Trailer:
  • Draw out table + Opening door, front chest and other compartments
  • Interior. Space for an elevated bed and seats on the bottom floor.
  • The camper has a 2 output gearbox that controls synchronized outtriggers + the pop-top roof
  • Camper Tailgate doubles as steps into the trailer
  • Spare wheels for both the Pickup truck and camper
  • Slide out Awning
  • Solid axle suspension with springs in the trailer
Some Photos
Edited by CrazyKreations
Changed some words and photos
3-Axle Mobile Crane
Functions:
  • Steering on 1st and 3rd axle with proportional angle on 3rd axle, and working steering wheel in cab
  • I6 engine driven by differential on 2nd axle, with 4 speed gearbox (gear shift stick located in cab)
  • Full suspension on all 3 axles
  • Simultaneous outrigger horizontal extension
  • Simultaneous outrigger vertical deployment (capable of lifting crane off the ground when not horizontally extended, and stabilizing the crane for lifting when fully extended)
  • Boom raising via XL LA
  • 3-stage telescopic boom, with ratchet mechanism for locking, extending to a maximum reach of 108 studs/86.4cm, with vertical reach of 93cm
  • Winch with ratchet lock
  • 360 degree superstructure rotation
  • Opening doors
Crane Dump Truck
Truck mode - 1st gearbox position
-Working steering
-Drive (rear 4 wheels)
-Tipping bed
Switching changes between the two modes and also deploys the stabilizing outriggers.
Crane mode - 2nd gearbox position
-Rotating turntable of the crane
-Main crane elevation
-Secondary crane elevation
Extra functions:
-Rear suspension on the 4 wheels
-Working steering wheel
-Working fake engine
-Tilting cabin
-Opening bed sides
-Winch mounted to the crane
-Opening doors
YouTube Presentation:
Discussion topic here:
Rotating telehandler
  • 4 wheel steering
  • Outriggers
  • Rotating upperstructure
  • Extending boom
  • Tilting cabin
Photos:
Topic:
Edited by CK28
Motorized lowrider
Manual functions:
  • Working steering actuated by the steering wheel
  • Fake Inline 4 engine driven by rear axle
  • Foldable roof (making it a convertible)
  • Openable hood, suicidal doors and bonnet
Motorized functions:
  • 4x Independent spring - assisted motorized suspension on all wheels powered by 2x PU and 2x PF L motors
  • All motors are controlled by a single BuWizz 3.0 located in the boot.
Other features:
  • Proper, clean and spacious interior
  • Detailed exterior featuring winglets, exhausts, wheel covers mirrors and more
Specifications:
  • Built out of 912 pieces
  • Weighs around 850 grams
  • 40 x 14,5 x 11 cm when totally raised
Edited by Zerobricks
City bus
Functions
  • Front steering, via HOG on roof. Driver's steering wheel turns along.
  • Rear wheels drives a 4-cylinder fake engine.
  • 2-speed gearbox. Via HOG on roof. The gearstick by the driver's seat moves along.
  • Opening/closing side doors, both connected, via HOG above the doors.
  • Rolling destination panel with tiles on a chain, to allow choosing destinations. Via HOG on sides. Uses Architecture 1x8 tiles to visit monuments worldwide ;)
  • Opening/closing rooftop windows. Both connected, via HOG on rear.
Discussion topic
Aircraft Simulator Truck
Functions:
  • Remote-controlled drive and steering
  • Remote-controlled aircraft pitch and roll with 2-way joystick
  • Opening doors, tilting cab, storage compartment
  • Various details such as seats, steering wheel, wipers, fuel tank, fire extinguisher, spare tire, etc.
Video:
Discussion topic:
Drift Kart and Driver
RC Kart:
  • Steering with exaggerated Ackermann geometry and 22° caster angle (PF servo)
  • Rear wheels drive with two PF M motors geared up and no differential
  • IR receiver disguised as a two-stroke liquid-cooled engine
Driver:
  • Uses battery box as body
  • Articulated arms for steering and counter-steering
  • Articulated head looking into corners
/!\ No toggle joint piece has been harmed during final model assembly
IQPOmnmeJNeJS4Iatqmaf6S0AUz1fxiK295z06wT
IQMfVr8f4bwLTojobT_EyhEnAT2Zj7miesARDy34
IQPxhRM6MISKQ6oatJtBLuFaAQIodqol8EZFugmx
  • Milan locked this topic
  • Milan unpinned this topic
