thekoRngear Posted July 26, 2024 Posted July 26, 2024 On 7/22/2024 at 12:20 PM, astyanax said: The 4 predecessors all needed "major work" as well, in the eyes of this community. See for example the Pimp Up My XYZ projects, all bringing substantial improvements. You gunna do that for P1? Hopefully? Quote
Unbrickme Posted July 26, 2024 Posted July 26, 2024 3 hours ago, Auroralampinen said: Well here is first in depht look at the gearbox Thank you very much for sharing this! I really enjoyed building the gearbox for this car! Also the exponential speed changes shocked me. So it looks like this car has two neutral gears. The first one is in the gearbox itself, and the second one is part of the DNR selector. Now imagine this transmission but with a multiplier stepper (45 degree intervals). We could stack two of these transmissions together and get a 64 speed transmission! I also wonder about any other applications with this drum fork system. Maybe we could see some full RC sets with a remotely controlled distribution gearbox? Quote
astyanax Posted July 26, 2024 Posted July 26, 2024 4 hours ago, thekoRngear said: You gunna do that for P1? Hopefully? Quote
thekoRngear Posted July 26, 2024 Posted July 26, 2024 (edited) 48 minutes ago, astyanax said: @jb70 come out come out and join forces (when it's time) Edited July 26, 2024 by thekoRngear Quote
danielhstahl Posted July 26, 2024 Posted July 26, 2024 According to Unbrickme's video, the ratios are 0.71 1.1 1.77 2.76 4.42 6.9 11.05 The actual P1's ratios seem to be closer to linear: 0.71 1.081710677 1.483732283 1.911095335 2.434547804 3.119768212 4.120276968 Quote
NV Lego technic Posted July 26, 2024 Posted July 26, 2024 14 minutes ago, thekoRngear said: @jb70 come out come out amd join forces (when it's time) After August 1st I can feel people waiting and hoping for the mod. Quote
Divitis Posted July 26, 2024 Posted July 26, 2024 A good way to look at it is mapping top speed over gear ratio, that gives a feeling of what's reasonable to achieve with the engine running at maximum rpm. The P1 can officially reach 350Km/h, divide it by eleven and you get a 32Km/h top speed in first gear. I bet your city car can do better. With the real ratios, that value is a much more reasonable 85Km/h. The Lego rations are clearly just for show. Not that that's bad, on the contrary in fact as they make the effect of gear shifting much more visible. @danielhstahl these numbers are a great find, thanks! Quote
LegoHoops Posted July 28, 2024 Posted July 28, 2024 (edited) The “MSO P1” is getting few more facelifts here and there. Playing around with ideas - nothing set in concrete, extended the mid rear bumper section, Fence System parts have been fitted and changed lower taillights. Thumb wheel is back to it’s original position, as the Small Panels have also moved outward too. I have replaced to original 12L Red Soft Axles with 11L versions to have a more robust connection at the 3L Connectors above the exhaust outlet with an Axle/Pin, rather than relying on the Soft Axles for the connection through the Liftarms. Also replaced the odd in your face Blue Axle/Pin in the Red #4 Connector with a Red Pin and Bar. MSO - McLaren Special Operations Edited July 28, 2024 by LegoHoops Quote
StudWorks Posted July 29, 2024 Posted July 29, 2024 13 hours ago, LegoHoops said: The “MSO P1” is getting few more facelifts here and there. Playing around with ideas - nothing set in concrete, extended the mid rear bumper section, Fence System parts have been fitted and changed lower taillights. Thumb wheel is back to it’s original position, as the Small Panels have also moved outward too. I have replaced to original 12L Red Soft Axles with 11L versions to have a more robust connection at the 3L Connectors above the exhaust outlet with an Axle/Pin, rather than relying on the Soft Axles for the connection through the Liftarms. Also replaced the odd in your face Blue Axle/Pin in the Red #4 Connector with a Red Pin and Bar. MSO - McLaren Special Operations Looks great, though I don't like the use of fence parts, looks odd IMO. Quote
jfb9301 Posted August 4, 2024 Posted August 4, 2024 (edited) NM, I answered my own question Edited August 4, 2024 by jfb9301 Quote
LvdH Posted August 5, 2024 Posted August 5, 2024 (edited) Let's see how it compares. First impression: Paper bags! Until today, I believed these to be a myth only sent to recognised reviewers. Edited August 5, 2024 by LvdH Quote
LvdH Posted August 6, 2024 Posted August 6, 2024 I either made a building mistake, or there is an error in the instructions. At page 193 they show you to test the gearbox, but in mine another gear spins while the other one rotates freely. Can anyone confirm if this is correct? I tested it, and the gears are in order, so I guess I built it correct. Not that I will ever use the gearbox, but I do want it to be right. Quote
LegoHoops Posted August 7, 2024 Posted August 7, 2024 (edited) 13 hours ago, LvdH said: I either made a building mistake, or there is an error in the instructions. At page 193 they show you to test the gearbox, but in mine another gear spins while the other one rotates freely. Can anyone confirm if this is correct? I tested it, and the gears are in order, so I guess I built it correct. Not that I will ever use the gearbox, but I do want it to be right. Check out the link below to Ramblingbrick - maybe the same error? https://ramblingbrick.com/2024/07/15/42172-lego-technic-mclaren-p1-unboxing-and-build-experience-i/#more-67467 Ramblingbrick Quote:- “Be careful with the gearbox. Take your time and get it right!” The advice I heard rings in my ears. Edited August 7, 2024 by LegoHoops Image Quote
Bluemethyst Posted August 7, 2024 Posted August 7, 2024 does anyone know a good disassembly guide or an easy way to split the build into 2 or 3 large pieces? I bought the thing in London and now I need to fly home to New Zealand and I don't know if I can be bothered to take it all apart... Quote
Zerobricks Posted August 7, 2024 Posted August 7, 2024 1 hour ago, Bluemethyst said: does anyone know a good disassembly guide or an easy way to split the build into 2 or 3 large pieces? I bought the thing in London and now I need to fly home to New Zealand and I don't know if I can be bothered to take it all apart... Follow the instructions in reverse Quote
TechnicRCRacer Posted August 7, 2024 Posted August 7, 2024 On 8/5/2024 at 9:13 AM, LvdH said: First impression: Paper bags! Until today, I believed these to be a myth only sent to recognised reviewers. Are you in the USA? I’ve just opened my copy and all the bags are plastic. I’ve been seeing European reviewers receive sets with paper bags for over a year and I haven’t gotten a set with them yet. Quote
LvdH Posted August 8, 2024 Posted August 8, 2024 (edited) 8 hours ago, TechnicRCRacer said: Are you in the USA? I’ve just opened my copy and all the bags are plastic. I’ve been seeing European reviewers receive sets with paper bags for over a year and I haven’t gotten a set with them yet. Nope, Europe. This is also my first set with paper bags. I did however get (so far) one small plastic bag inside one of the bags, and the “extra” pieces like the frames and wishbones did come in a plastic bag. Edited August 8, 2024 by LvdH Quote
NV Lego technic Posted August 8, 2024 Posted August 8, 2024 If you check reviews on the internet, you'll see that their sets arrived like that, so everything is good. Quote
Wolfolo Posted August 8, 2024 Posted August 8, 2024 Did they remove the QR code for the LEGO Builder's app (and to redeem the 20 insider points)? I looked in the manuals but I only found links to download the app, access to the insider's area to redeem the content with the tile code, info on packaging... Quote
LegoHoops Posted August 8, 2024 Posted August 8, 2024 (edited) The McLaren P1 arrived yesterday, it is disappointing that these flagship sets are arriving containing the crazy amount of plastic bags. Information on the outer LEGO box - Country of Origin:- CN (China) 14/5/24. Hopefully with next 1:8 car TLG will celebrate the 10th Anniversary with all paper bags! Let the fun begin…. Edited August 8, 2024 by LegoHoops Quote
Sokolov Edward Posted August 8, 2024 Posted August 8, 2024 29 minutes ago, LegoHoops said: The McLaren P1 arrived yesterday, it is disappointing that these flagship sets are arriving containing the crazy amount of plastic bags. Information on the outer LEGO box - Country of Origin:- CN (China) 14/5/24. Hopefully with next 1:8 car TLG will celebrate the 10th Anniversary with all paper bags! Don't you think it's strange that you are unhappy with the packaging of plastic parts in plastic bags!? There is less plastic in a plastic bag than in a black pin. Quote
LegoHoops Posted August 8, 2024 Posted August 8, 2024 (edited) 12 hours ago, Sokolov Edward said: Don't you think it's strange that you are unhappy with the packaging of plastic parts in plastic bags!? There is less plastic in a plastic bag than in a black pin. Yeah, fully understand the irony of that, but we are not generally throwing Lego in the bin. I still have bits from 45 years ago, probably like many others or bins of Lego that has been passed through multiple families over years. Edited August 9, 2024 by LegoHoops Grammar Quote
Aurorasaurus Posted August 9, 2024 Posted August 9, 2024 9 hours ago, LegoHoops said: Yeah, fully understand the irony of that, but we are not generally throwing Lego in the bin. I still have bits for 45 years ago, probably like many others or bins of Lego that has been passed through multiple families over years. Yep, my family too, the old lego is still going strong. Quote
2GodBDGlory Posted August 9, 2024 Posted August 9, 2024 8 hours ago, Aurorasaurus said: Yep, my family too, the old lego is still going strong. Oh yeah! I inherited my Dad's/Uncles' Lego collection (Mostly classic Space) on my fifth birthday, and have been at it ever since! Quote
